Auteur Topic: DSC-decoder  (gelezen 25820 keer)
Offline Harold
Re: DSC-decoder
« Reactie #15 Gepost op: 20 maart 2008, 21:26:53 »
Volgens mij vraagt de Kustwacht of de reddingsboot naar Marifoon kanaal 83 komt. En of ze dat met een DSC antwoord willen bevestigen.
Harold,
Offline Scannernet.nl
    • Scannernet.nl
Re: DSC-decoder
« Reactie #16 Gepost op: 23 maart 2008, 16:37:44 »
inmiddels heb ik ook DSC-decoder aangeschaft en vandaag ben ik er ff wat mee aan het "klooien" geweest. Hier een resultaat....
ATIS (atis) from 9244042149 (PD2149) EOS [08-03-23 16:31:13]
ATIS (atis) from 9244042149 (PD2149) EOS [08-03-23 16:30:56]
# unknown format  ACK [08-03-23 15:12:14]
ALCESTIS,C6NP8-BAH (routine) from ALCESTIS,C6NP8-BAH  F3 ch69VHF/no freq ACK [08-03-23 14:30:59]
ATIS (atis) from ?9244047505 (PD7505) EOS [08-03-23 13:59:21]
ATIS (atis) from ?9244047505 (PD7505) EOS [08-03-23 13:59:13]
ATIS (atis) from ?9244042749 (PD2749) EOS [08-03-23 13:15:40]
# ATIS (atis) from ?10844042749  EOS [08-03-23 13:15:31]
all ships (distress) from [Netherlands CG]-HOL DISTRESS ack CANATA,DD8711-D man overboard N52° 53' E005° 24'  12:57UTC  F3 ACK [08-03-23 12:57:51]
DISTRESS (distress) from CANATA,DD8711-D man overboard N52° 53.1000' E005° 24.0000'  12:57UTC  F3 EOS [08-03-23 12:57:23]
DISTRESS (distress) from CANATA,DD8711-D man overboard N52° 53' E005° 24'  12:57UTC  F3 EOS [08-03-23 12:57:23]
DISTRESS (distress) from CANATA,DD8711-D man overboard N52° 53' E005° 24'  12:57UTC  F3 EOS [08-03-23 12:57:22]
DISTRESS (distress) from CANATA,DD8711-D man overboard N52° 53' E005° 24'  12:57UTC  F3 EOS [08-03-23 12:57:21]
WATFORD,S6HB6-SNG (urgency) from [Netherlands CG]-HOL  F3 ch16VHF/ch16VHF REQ [08-03-23 10:10:55]
!# WATFORD,S6HB6-SNG (urgency) from ?002438000-HNG  F3 ch16VHF/ch16VHF [08-03-23 10:10:55]
ATIS (atis) from ?9244094329 (PI4329) EOS [08-03-23 09:21:26]
ATIS (atis) from ?9244094329 (PI4329) EOS [08-03-23 09:21:17]
ATIS (atis) from ?9244094329 (PI4329) EOS [08-03-23 09:21:06]
ATIS (atis) from ?9244035557 (PC5557) EOS [08-03-23 07:05:29]
ATIS (atis) from ?9244035557 (PC5557) EOS [08-03-23 07:05:13]
Ik had de scanner op kanaal 70 (156.525) gezet.
Ik kan in de Help-file niets vinden over het gewenste audio-level. Weet misschien iemand anders hier op het forum hoe hard de scanner moet staan?
Kunnen er ook meerdere kanalen gescand worden of is het beter dat de ontvanger op één kanal "vast" staat (net als bij Shipplotter).
Bas
Kijk ook eens op Scannernet.nl voor Live Scanners, Live AIS, Flightradars & meer.....
Volg ook onze Twitter & Facebook
Offline Harold
Re: DSC-decoder
« Reactie #17 Gepost op: 24 maart 2008, 20:15:06 »
Alle DSC berichten gaan via kanaal 70.
De ontvangen ATIS nummers zijn de roepletters van een nederlands schip, dat iets heeft uitgezonden.
Elke (Nederlandse) marifoon zend dit digitale berichtje uit als de spreeksleutel wordt losgelaten.
Harold,
Re: DSC-decoder
« Reactie #18 Gepost op: 25 maart 2008, 07:05:18 »
Citaat van: "Harold"
Dat klopt als je spreekt over marifoons die op de binnenwateren gebruikt mogen worden. Globaal gebruiksgebied: Benelux, Frankrijk, Duitsland en Zwitserland. Zeevarende schepen hebben geen ATIS systeem in de marifoon. In de rest van de wereld kennen ze het systeem niet eens.
mvg,
Leen
Offline jomaco
Re: DSC-decoder
« Reactie #19 Gepost op: 26 maart 2008, 00:33:08 »
Citaat van: "Arle"
Nu is mijn vraag; wat betekent die F3? Wil dat zeggen dat ze op ch83VHF uitluisteren o.i.d.?
F3 = F3E = FM
http://nl.wikipedia.org/wiki/Frequentiemodulatie
Re: DSC-decoder
« Reactie #20 Gepost op: 26 maart 2008, 01:53:48 »
Citaat van: "jomaco"
F3 = F3E = FM
Even tussen neus en lippen door:
Mag ik vragen waarom je dit forum heb lopen vandaliseren en ontregelen?
Je hebt 99% van je berichten leeg zitten maken... Nu zijn er onderwerpen zonder startpost, reageren mensen op leeggemaakte berichten en zo kan ik nog wel even doorgaan...
Re: DSC-decoder
« Reactie #21 Gepost op: 1 november 2014, 17:11:36 »
Ik heb sinds deze week ook DSCdecoder gedownload. Werkt perfect met ATIS, DSC nog niks binnen gekregen op kanaal 70
Is het mogelijk om de MMSI lijst van AT in dit progamma te krijgen? Het ATISinfo lijstje van het progamma kan ik niet aanpassen en ben tot nu toe geen andere mogelijkheid tegen gekomen wat wel werkt.
Ik draai momenteel nog de free trail versie :-)
Offline Jarod
Re: DSC-decoder
« Reactie #22 Gepost op: 2 november 2014, 06:33:33 »
Hier zelf ook met de DSCdecoder bezig geweest, alleen dan voor het langegolf DGPS gedeelte:
http://x264.nl/dump/dgps_list.txt mijn resultaten. Leuk programma!
