Auteur Topic: dPMR  (gelezen 24686 keer)
dPMR
« Gepost op: 11 juli 2025, 11:22:32 »
KENWOOD TK-3701D standaardinstellingen
Analoog, zone 1
Kenwoord-kanaal Rx CTCSS/DCS PMR/DMR-kanaal
1   446.006250 MHz 94.8 Hz 1
2   446.093750 MHz 88.5 Hz 8
3   446.031250 MHz 103.5 Hz 3
4   446.068750 MHz 79.7 Hz 6
5   446.043750 MHz 118.8 Hz 4
6   446.018750 MHz 123.0 Hz 2
7   446.081250 MHz 127.3 Hz 7
8   446.056250 MHz 85.4 Hz 5
9   446.006250 MHz 107.2 Hz 1
10 446.093750 MHz 110.9 Hz 8
11 446.031250 MHz 114.8 Hz 3
12 446.068750 MHz 82.5 Hz 6
13 446.043750 MHz D132N 4
14 446.018750 MHz D155N 2
15 446.056250 MHz D134N 5
16 446.081250 MHz D243N 7
Digitaal, zone 2
Kenwood-kanaal Rx dPMR-kanaal
1   446.103125 MHz 17
2   446.109375 MHz 18
3   446.115625 MHz 19
4   446.121875 MHz 20
5   446.128125 MHz 21
6   446.134375 MHz 22
7   446.140625 MHz 23
8   446.146875 MHz 24
9   446.153125 MHz 25
10 446.159375 MHz 26
11 446.165625 MHz 27
12 446.171875 MHz 28
13 446.178125 MHz 29
14 446.184375 MHz 30
15 446.190625 MHz 31
16 446.196875 MHz 32
Digitaal, zone 3
1   446.003125 MHz 1
2   446.009375 MHz 2
3   446.015625 MHz 3
4   446.021875 MHz 4
5   446.028125 MHz 5
6   446.034375 MHz 6
7   446.040625 MHz 7
8   446.046875 MHz 8
9   446.053125 MHz 9
10 446.059375 MHz 10
11 446.065625 MHz 11
12 446.071875 MHz 12
13 446.078125 MHz 13
14 446.084375 MHz 14
15 446.090625 MHz 15
16 446.096875 MHz 16
dPMR-kanalen:
rx omschrijving
446.00313 Digitale PMR kanaal 1
446.00938 Digitale PMR kanaal 2
446.01563 Digitale PMR kanaal 3
446.02188 Digitale PMR kanaal 4
446.02813 Digitale PMR kanaal 5
446.03438 Digitale PMR kanaal 6
446.04063 Digitale PMR kanaal 7
446.04688 Digitale PMR kanaal 8
446.05313 Digitale PMR kanaal 9
446.05938 Digitale PMR kanaal 10
446.06563 Digitale PMR kanaal 11
446.07188 Digitale PMR kanaal 12
446.07813 Digitale PMR kanaal 13
446.08438 Digitale PMR kanaal 14
446.09063 Digitale PMR kanaal 15
446.09688 Digitale PMR kanaal 16
446.10313 Digitale PMR kanaal 17
446.10938 Digitale PMR kanaal 18
446.11563 Digitale PMR kanaal 19
446.12188 Digitale PMR kanaal 20
446.12813 Digitale PMR kanaal 21
446.13438 Digitale PMR kanaal 22
446.14063 Digitale PMR kanaal 23
446.14688 Digitale PMR kanaal 24
446.15313 Digitale PMR kanaal 25
446.15938 Digitale PMR kanaal 26
446.16563 Digitale PMR kanaal 27
446.17188 Digitale PMR kanaal 28
446.17813 Digitale PMR kanaal 29
446.18438 Digitale PMR kanaal 30
446.19063 Digitale PMR kanaal 31
446.19688 Digitale PMR kanaal 32
PMR/DMR-kanalen
rx omschrijving
446.00625 PMR446 / DMR446 kanaal 1
446.01875 PMR446 / DMR446 kanaal 2
446.03125 PMR446 / DMR446 kanaal 3
446.04375 PMR446 / DMR446 kanaal 4
446.05625 PMR446 / DMR446 kanaal 5
446.06875 PMR446 / DMR446 kanaal 6
446.08125 PMR446 / DMR446 kanaal 7
446.09375 PMR446 / DMR446 kanaal 8
446.10625 PMR446 / DMR446 kanaal 9
446.11875 PMR446 / DMR446 kanaal 10
446.13125 PMR446 / DMR446 kanaal 11
446.14375 PMR446 / DMR446 kanaal 12
446.15625 PMR446 / DMR446 kanaal 13
446.16875 PMR446 / DMR446 kanaal 14
446.18125 PMR446 / DMR446 kanaal 15
446.19375 PMR446 / DMR446 kanaal 16
Voor Icom zie tabel in https://icomuk.co.uk/files/icom/PDF/productManual/IC-F29DR_MLT_IM_4a.pdf
Re: dPMR
« Reactie #1 Gepost op: 11 juli 2025, 11:59:56 »
Maar nu nog die ID's er bij zien te programmeren in mijn SDS200E.
Re: dPMR
« Reactie #2 Gepost op: 11 juli 2025, 12:26:06 »
Met ARC260 kan ik een SQ Code invoeren. Op een UBCD160DN moet je Audio Type op Digital Only zetten om een Common ID in te kunnen voeren in een submenu dat je dan krijgt onder Audio Type.
Re: dPMR
« Reactie #3 Gepost op: 11 juli 2025, 12:31:34 »
Ik zie die optie nu in ARC536 ook staan.
Dan zou ik dus in theorie de ID's van de Icom en Kenwood apparatuur er in kunnen zetten.
Maar in 1 van de links die Alwin stuurde las ik al dat die ID aangepast kan worden.
Re: dPMR
« Reactie #4 Gepost op: 11 juli 2025, 12:37:27 »
Re: dPMR
« Reactie #5 Gepost op: 11 juli 2025, 13:11:23 »
Yep, net als met CTCSS / DCS. Vandaar dat ik "standaardinstellingen" schreef.
Voor PMR heb ik daarom meerdere bankjes. PMR: zonder CTCSS / DCS. Kenwood: met de standaardinstellingen van Kenwood. Met het Kenwood-bankje zul je minder snel kinderen met een portofoon van de Action horen.
Gewijzigde Common ID (en CTCSS / DCS) zal voornamelijk voorkomen bij professionele gebruikers.
Re: dPMR
« Reactie #6 Gepost op: 11 juli 2025, 13:13:54 »
Zo heb ik het nu inderdaad ook gedaan met dPMR. Met PMR had ik dat al gedaan maar soms sluipen er toch nog een paar doorheen.
Offline Wassenaar
Re: dPMR
« Reactie #7 Gepost op: 11 juli 2025, 14:31:50 »
Al wat gehoord op dPMR behalve rijscholen in jouw hoek Johan ?
Wsn
Re: dPMR
« Reactie #8 Gepost op: 11 juli 2025, 14:32:23 »
Nog helemaal niks.
Offline Wassenaar
Re: dPMR
« Reactie #9 Gepost op: 11 juli 2025, 14:39:12 »
Dat bedoelde ik, in zuid west alleen maar rijscholen….
Re: dPMR
« Reactie #10 Gepost op: 11 juli 2025, 14:40:58 »
Maar ik snap het niet, voordat ik dPMR kon luisteren hoorde ik volop digitale signalen op PMR.
En nu is daar helemaal niets meer van over.
Re: dPMR
« Reactie #11 Gepost op: 11 juli 2025, 14:53:04 »
Kenwood instellingen zijn weer anders.
Kunnen bovendien ook eenvoudig aangepast worden.
Scanner op search zetten.
Offline Wassenaar
Re: dPMR
« Reactie #12 Gepost op: 11 juli 2025, 14:57:06 »
Zo heb ik de 32 kanalen er inderdaad ook staan, dus met search.
Wellicht dat het lokaal bij ons in het Haagse wordt gebruikt, door tot nu toe alleen rijscholen.
Re: dPMR
« Reactie #13 Gepost op: 11 juli 2025, 16:43:40 »
Is toch zelfde als wat ik schreef in eerste post van dit draadje?
Re: dPMR
« Reactie #14 Gepost op: 11 juli 2025, 18:50:37 »
Klopt, ik zag alleen onderste deel. Maar zie nu dat er een scroll functie in zit (zag ik op mijn telefoon niet, nu op de pc wel).
