Auteur Topic: Werewolf Resillience  (gelezen 11734 keer)
Offline Superfuse
« Gepost op: 8 oktober 2020, 16:22:47 »
https://www.defensie.nl/binaries/defensie/documenten/besluiten/2020/10/07/oefening-werewolf-resilience/Ondertekende+beschikking+TGB%27s+Deelen+Twente+en+Marnewaard+%28Werewolf+Resilience%29.pdf
TEMPORARY RESTRICTED AREA 'MARNEWAARD' ACTIVATED FOR MIL EXER
'WEREWOLF RESILIENCE'
AREA: 531322N 0061139E ALONG 10NM RADIUS ARC WITH CENTRE 532300N
0061600E CLOCKWISE TO 532254N 0063242E AND BACK TO 531322N 0061139E
BTN GND/FL065.
AREA PROHIBITED. SAR, POLICE, HELICOPTER MEDICAL EMERGENCY SERVICES
AND COORDINATED FLIGHTS ARE EXEMPTED AFTER PRIOR PERMISSION FROM
MILATCC SCHIPHOL. GND - FL065, MON-FRI 0800-1100 1330-1630 1900-2200, 23 NOV
08:00 2020 UNTIL 11 DEC 22:00 2020. CREATED: 08 OCT 11:36 2020
TEMPORARY RESTRICTED AREA 'TWENTE' ACTIVATED FOR MIL EXER
AREA: PSN 521633N 0065321E 10NM RADIUS BTN GND/FL065. GERMAN
AIRSPACE EXCLUDED.
08:00 2020 UNTIL 11 DEC 22:00 2020. CREATED: 08 OCT 11:16 2020
TEMPORARY RESTRICTED AREA 'DEELEN' ACTIVATED FOR MIL EXER
AREA: PSN 520335N 0055219E 6,5NM RADIUS BTN GND/FL095. RESTRICTED
AREAS EHR9 (HARSKAMP) AND EHR61 (ARNHEMSE HEIDE) ARE EXCLUDED.
MILATCC SCHIPHOL. GND - FL095, MON-FRI 0800-1100 1330-1630 1900-2200, 23 NOV
08:00 2020 UNTIL 11 DEC 22:00 2020. CREATED: 08 OCT 10:44 2020
Offline Superfuse
Re: Werewolf Resillience
« Reactie #1 Gepost op: 19 oktober 2020, 12:17:14 »
IN MIL EXERCISE 'WEREWOLF RESILIENCE' INTENSE MIL ACTIVITY CAN
BE EXPECTED BELOW MNM VFR ALT WITHIN AREA 'WEREWOLF RESILIENCE
NOORD':
522810N 0055058E - 522525N 0061509E - 530957N 0062003E - 532254N
0063242E - 531322N 0061139E ALONG CLOCKWISE ARC (RADIUS 10NM WITH
CENTRE 532300N 0061600E) TO 532348N 0055921E - 524306N 0055342E -
530404N 0051753E - 525609N 0050240E - 524236N 0051826E BACK TO
522810N 0055058E BTN GND/FL065. EHLW CTR EXCLUDED. REQ TO AVOID AREA. GND -
FL065, MON-FRI 0800-1100 1330-1630 1900-2200, 23 NOV 08:00 2020 UNTIL 11 DEC
22:00 2020. CREATED: 12 OCT 09:11 2020
WEST':
511953N 0052841E - 513050N 0051047E - 515228N 0052523E - 514900N
0045600E - 513544N 0040704E - 511645N 0040806E ALONG THE
DUTCH-BELGIAN BORDER TO 511755N 0052900E BACK TO 511953N 0052841E
BTN GND/FL065. NATURE RESERVE AREA 'MARKIEZAAT' EXCLUDED. REQ TO
AVOID AREA. GND - FL065, MON-FRI 0800-1100 1330-1630 1900-2200, 23 NOV 08:00
2020 UNTIL 11 DEC 22:00 2020. CREATED: 12 OCT 08:47 2020
BE EXPECTED BELOW MNM VFR ALT WITHIN AREA 'WEREWOLF RESILIENCE':
511953N 0052841E - 512448N 0055419E ALONG ANTI CLOCKWISE ARC (RADIUS
6.5NM WITH CENTRE 513105N 0055127E) TO 513712N 0055448E - 515326N
0055447E - 521008N 0064515E ALONG ANTI CLOCKWISE ARC (RADIUS 8NM
WITH CENTRE 521608N 0065350E) TO 520811N 0065229E ALONG THE
DUTCH-GERMAN BORDER TO 522059N 0070411E ALONG ANTI CLOCKWISE ARC
(RADIUS 8NM WITH CENTRE 521608N 0065350E) TO 522156N 0064453E -
522810N 0055058E - 521332N 0053950E - 513050N 0051047E BACK TO
511953N 0052841E BTN GND/FL065. REQ TO AVOID AREA. GND - FL065, MON-FRI 0800-1100
1330-1630 1900-2200, 23 NOV 08:00 2020 UNTIL 11 DEC 22:00 2020. CREATED: 12 OCT
08:18 2020
Offline Superfuse
« Reactie #2 Gepost op: 29 oktober 2020, 08:26:37 »
TEMPORARY RESTRICTED AREA 'WEELDE A' ACTIVATED FOR FOR MIL EXER
'WEREWOLF RESILIENCE'.
AREA: PSN 512339N 0045733E WITH 6NM RADIUS BTN GND/3500FT AMSL. EHGR
CTR AND EBBU FIR EXCLUDED.
AREA PROHIBITED. POLICE, SAR AND MEDICAL FLIGHTS ARE EXEMPTED.
PARTICIPATING AND AUTHORISED CROSSING TFC CONTACT MILATCC SCHIPHOL
PRIOR ENTERING AREA. GND - 3500FT AMSL, DAILY 1330-1630 1900-2200, 07 DEC 13:30
2020 UNTIL 11 DEC 22:00 2020. CREATED: 29 OCT 08:14 2020
Offline Lord Flashheart
  • Boardmoderator
    • 24 December 1944
« Reactie #4 Gepost op: 23 november 2020, 19:13:36 »
Ops gehoord en gelogd door user Gizmo436, leuke log!
Werewolf Ops 298.950 -> Wow, hoe kom ik hier nu weer op dan... Onderstaande reactie van Belenos is de enige juiste.  :-[
Offline Belenos
« Reactie #5 Gepost op: 24 november 2020, 16:30:07 »
Juiste freq is 259.250 :-)
  • Boardmoderator
    • 24 December 1944
« Reactie #6 Gepost op: 25 november 2020, 16:11:31 »
Ik kom nu tot dusver:
138.300 Ops
244.625 Air/Air.
256.300 A/G met Torch.
259.250 Ops (Nu wel goed Belenos :) )
315.150 weet ik niet goed te benamen.. Tactical?
337.950 Para Control.
399.425 Onbekend, altijd secure.
Verder ook de standaard FAC freq(s)
315.625 en wellicht zijn er meerdere al gebruikt.
Meen dat er ook al een VHF para freq was gelogd. Iemand die wellicht die kan aanvullen.
Offline Thijsiooh
« Reactie #7 Gepost op: 25 november 2020, 18:28:29 »
Qua para-control heb ik de volgende staan:
122.810 of 122.800? Ook regelmatig in gebruik door de Skyvan
143.850
  • Boardmoderator
    • 24 December 1944
« Reactie #8 Gepost op: 25 november 2020, 19:10:53 »
143.850
Dank voor deze aanvulling. 143.850 was diegene die ik bedoelde als VHF. 122.800 had ik ook gelezen. Skyvan staan los van deze oefening en die zat idd op de 122.810.
Offline Warlord32
« Reactie #9 Gepost op: 25 november 2020, 19:54:01 »
138.300 Ops
244.625 Air/Air.
378.950 boven marne > secure
en 142.325 voor de roques  nog
Offline Belenos
« Reactie #10 Gepost op: 25 november 2020, 21:37:05 »
138.300 Ops
244.625 Air/Air.
315.150 is 313.150 ;-) verder alles goed Lord
  • Boardmoderator
    • 24 December 1944
« Reactie #11 Gepost op: 26 november 2020, 06:07:58 »
138.300 Ops
244.625 Air/Air.
:-[ Het lukt me toch elke keer weer... zucht.
@Warlord32, dank voor de aanvulling.
Offline Belenos
« Reactie #12 Gepost op: 29 november 2020, 09:35:20 »
Add
339.750 TORCH (s)
378.950 is TORCH (p)
Offline gizmo436
« Reactie #13 Gepost op: 30 november 2020, 12:47:53 »
kleine aanvulling op de 259.250
259.250 = BULL OPS
Offline Warlord32
« Reactie #14 Gepost op: 30 november 2020, 20:33:57 »
138.800 ?
278.825 torch
