Auteur Topic: SDR# Plug-in: Frequency Scanner updated  (gelezen 8192 keer)
Offline Warlord32
« Gepost op: 26 maart 2020, 17:16:43 »
This plug-in version adds/changes and fixes some items:
Code:
v1.2.0.0
Changed: Graphic for 'Lock' and 'Unlock' buttons in Channel analyser.
Changed: Channel analyser buttons 'Lock' and 'Unlock' are disabled during scanning to avoid accidental usage.
Changed: Reworked UI for better visibility on Telerik SDR# (1717+) and darker themes.
Added: 'Configure' - option for adjusting fade speed for on screen buttons in channel analyser.
Added: Quick zoom function (when scroll wheel clicked)
Changed: On screen 'Now Playing'
- Previously this has been made up of 'Frequency Group Name' (as sourced from the 'Frequency Manager' plug-in database)
- It will now display in the following format: 'Frequency: Group - Name'
Added: 'Now Playing' file which can be used when streaming audio (via Icecast + butt or RadioFeed) with ability to synchronize to audio.
Fixed: 'Edit scan ranges' - When exiting a empty field, it would cause an exception.
Fixed: On occasions when scanner stopped, an exception would occur.
Added: Ability to run scanner without channel analyser.
Fixed: When scanner was stopped, some code was left running which continued to consume CPU cycles (6% for me).
Added: On SDR# start-up, the Frequency scanner plug-in will backup the 'scanner_entryes.xml' to 'scanner_entryes.xml.bak'.
Added: Option to restrict set/clear of lockouts and lockout range to bottom 80-100% of channel analyser panel.
Added: PDF Documentation
- Please read it
see 'changelog.txt' for full list and details.
https://forums.radioreference.com/threads/sdr-plug-in-frequency-scanner-updated.402110/
Offline Warlord32
Re: SDR# Plug-in: Frequency Scanner updated
« Reactie #1 Gepost op: 30 maart 2020, 07:51:58 »
Code:
Summary of changes
1.3.0.0 - Release
- Please read it
Added: 8.33 Khz channel selector
Added: Channel analyser range colours
Added: Disable channel analyser refreshing (after 300 seconds)
Change/Added: Noise protection delay
- Now adjustable for ON(new) and OFF
  This should minimise/stop the mute chopping in and out that was more noticable when using SDR# 1717+.
Changed: 8.33 KHz start frequency rounding
Changed: Zoom (Scrollwheel and quick)
- Two types of zoom focus have been created.
-- 1. Will zoom in on (last) active frequency. (New)
-- 2. Will zoom in on position of mouse cursor.
Fix: Crash when click 'lockout'/ 'remove lockout' buttons when active frequency is not in view (zoomed in)
- Will now hear beep when this condition exists. No lockout state will be changed. (Frequency must be in view)
Changed: Allow SDR# mute to be manually changed while scanner is in paused condition.
- This will mean that SDR# mute will not automatically function in the paused state.
Added: Ability to scan with correct 8.33 Khz step size for Airband.
see 'chanelog.txt' for full details
https://mega.nz/#F!WOhgiYjB!_V0Fr0eu3UxFWXzytAZsIA
Offline Warlord32
« Reactie #2 Gepost op: 30 maart 2020, 09:13:39 »
1.3.0.1 - Release (Minor)
Fixed: 'Auto skip' is not muting when it continues scanning
- When 'Audio mute' and 'Auto skip' is used and SDR# squelch is not used.
  When auto skip continues the scan, the SDR# mute is not re-activated making the noise floor heard until next active frequency found.
- Also applies to Next/Previous buttons.
Offline Bartmans
« Reactie #3 Gepost op: 30 maart 2020, 09:22:18 »
Dank u wel voor de info
Offline Warlord32
« Reactie #4 Gepost op: 3 april 2020, 09:10:00 »
1.3.1.0
Fixed: 'Configure' lost click events for controls
- When re-arranging the 'Configure' window, click events where lost which caused some of the controls not to
   register any changes.
Fixed: 'Configure' Noise protection delay 'ON'
- The introduction of this option was causing the auto audio mute not to function properly when
   Forward/Reverse/Lockout buttons and auto skip and direct manual lockout where used.
- Reversed some changes in v1.3.0.1 as those change where caused by this issue.
Added: 'Force manual audio mute when paused' option in 'Configure' > 'Scanner'
- This was default action since v1.2.2.6, this is no longer the case.
- As a result of other changes, forcing a manual audio mute is not really needed now as changing the
   frequency while paused activates that frequency to allow the auto muting to function as expected.
- I added as option to allow those who may still like manual control of mute while paused.
- Please read it
Offline Warlord32
« Reactie #5 Gepost op: 16 april 2020, 06:39:58 »
1.3.2.0
Changed: Stored settings entries have been prefixed (fScanner.) to help group them in SDR# '.Config' file.
- This means that you will need to reconfigure the plug-in for this release.
Added: Channel analyser button to quick toggle the zoom type (Z1/Z2)
- Button is located to the right of the 'Remove lockout' button.
- Z1 = Centred zoom.
  Z2 = Cursor position zoom.
- This is the same as using 'Disable focus zoom on active frequency' option in 'Configure'
Changed: Mouse cursor frequency label position.
- Vertical position is now variable depending on mouse position in channel analyser.
Changes: To various channel analyser code
- Moved some parts of the code into relevent sections.
- Trigger and Hysteresis line changed to a dash line.
- Mouse cursor vertical line changed to a dotted line.
- Side scale was not offset correctly.
Fixed: The last defined frequency range if selected (in plug-in side panel) was not restored to been
        selected on SDR# start.
Fixed: Auto audio mute did not mute when manually pause on active frequency then lock it out then play again.
Updated: PDF Documentation
- Please read it
