Auteur Topic: L-band gehoord tussen 1540 - 1550 MHz  (gelezen 27830 keer)
opabert
« Gepost op: 7 januari 2020, 22:59:13 »
1544.4 MHz - mode FM (JAERO software)
1545.0 MHz - AERO (ACARS) - mode USB - 600 BPS (JAERO software)
Offline Alwin_R09
  • Lima Charlie
    • Scanner Radio
Re: L-band gehoord tussen 1540 - 1550 MHz
« Reactie #1 Gepost op: 8 januari 2020, 11:34:17 »
1546.095 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.110 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.125 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.135 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.140 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.145 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.150 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.155 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.160 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.170 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.175 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.180 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.185 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.190 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
1546.195 MHz - AERO-H+ traffic channel ambe codec OQPSK 8400bps
Offline Alwin_R09
  • Lima Charlie
    • Scanner Radio
« Reactie #2 Gepost op: 8 januari 2020, 11:57:05 »
Kleine correctie en toevoeging op het bovenstaande.
1545.120 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.125 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.130 MHz - AERO (ACARS) - mode USB - 1200 BPS
1545.135 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.165 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.170 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.190 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.195 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.225 MHz - AERO (ACARS) - mode USB - 600 BPS
1545.230 MHz - AERO (ACARS) - mode USB - 600 BPS
1546.095 MHz - AERO (ACARS/ADS-C?) - mode USB - 10500 BPS
1546.110 MHz - AERO (ACARS/ADS-C?) - mode USB - 10500 BPS
1546.125 MHz - AERO (ACARS/ADS-C?) - mode USB - 10500 BPS
Offline boomer
  • You don't have to scream i hear you anyway !
    • SWL NL6777
« Reactie #3 Gepost op: 9 januari 2020, 14:28:05 »
1546.175 ( ambe codec )  regelmatig USAF, maar ook oa de TD van de KLM.  Ik gebruik de sdrplay als ontvanger en een 1.40 schotel.
3 x UBC 780xlt,NRD-515,NRD 545
4 xLowe R535.AOR 5000. Icom 8500,Icom 9000, Icom 8600, SDR Play, AOR DV-1.Icom r 30
Radarcape, SBS 1e, SBS 3, Ant GP1090  1090 A, Jetvision Air ! Squitter. Jaero/inmarsat voice
 Ant 25 el. Log per Hor/Ver, DX one Wellbrook ALA 1530 procom cxl 225, Procom cxl
opabert
« Reactie #4 Gepost op: 9 januari 2020, 15:37:18 »
Met 1.40 m  schotel dan denderen die signalen naar binnen :)
Boven de 25 SNR ?
opabert
« Reactie #5 Gepost op: 9 januari 2020, 17:40:17 »
1545.000 - 1545.500 - NFM - trunking en simplex gehele gebied (grote schotel nodig + LNA)
opabert
« Reactie #6 Gepost op: 13 januari 2020, 15:24:52 »
Als je deze signalen in SDR# ziet verschijnen
dan werkt je antenne goed en heb je ruim voldoende ontvangst voor alle ACARS freq.
Offline JimB
« Reactie #7 Gepost op: 13 januari 2020, 19:24:24 »
Is het misschien mogelijk om wat meer logjes te laten zien/horen? Om zo (misschien) wat meer interesse hierin te krijgen.
Jouw foto lijkt trouwens wel verdacht veel op de foto die ook te vinden is op deze link.  ;D
https://www.rtl-sdr.com/preorder-sale-active-l-band-1525-1637-inmarsat-to-iridium-patch-antenna-set-for-34-95/
opabert
« Reactie #8 Gepost op: 13 januari 2020, 23:13:01 »
Muis op het plaatje en je de rechter muisknop indrukt, in het menu de keuze maakt voor : "Afbeeldingslocatie kopieren" kom je uit op het  rtl-sdr.com adres  ;)
Persoonlijk heb ik niet / nooit de intentie om log files of  COMM informatie te publiceren en beschrijf alleen wat je nodig hebt.
De signalen op het plaatje,  zijn in geheel West en Noord Europa op de zelfde frequentie  te ontvangen. Het dupliceren van informatie of plaatjes is een overbodige handeling.
De verwijzing naar het plaatje op rtl-sdr.com en welke een uitstekend beeld geeft van de werkelijkheid en met de juiste antenne kan jij dit in NL ontvangen.
Offline JimB
« Reactie #9 Gepost op: 14 januari 2020, 07:41:52 »
Okay, zelf kon ik niet helemaal de toegevoegde waarde van jouw (eerste) post plaatsen.  Maar toch bedankt voor je moeite!
Inmiddels wel de benodigde en nuttige informatie, voor mij, via een forumlid ontvangen.
opabert
« Reactie #10 Gepost op: 14 januari 2020, 13:25:54 »
In een van mijn berichten staat een link naar de website van satcom en L-band en op die zelfde website staan aantal frequenties genoemd.
AERO is volkomen anders dan ACARS op VHF of ADS-B op 1090,  L-band  hoef je niet te wachten want de AERO draaggolf staan continu  24/7 in de lucht. Zodra je zelf ontvangst hebt,  zie je die frequenties altijd in SDR#  die AERO draaggolf kan je niet / nooit missen.  Als jij niet die 12x AERO  en 8x NCSC draaggolven ziet,   dan werkt je antenne niet.
opabert
« Reactie #11 Gepost op: 14 januari 2020, 15:55:54 »
Aanvulling om helderheid te geven.
Pas als jij de AERO en NCSC bakens sterk genoeg kan ontvangen,  werkt je antenne goed en kan je proberen om de voice channels te ontvangen.
Voice channels  gebruiken "beam of narrow beam / spot" deze hebben een signaal sterkte tussen minimaal 6 tot 18 en die moet je zelf opzoeken.
opabert
« Reactie #12 Gepost op: 29 januari 2020, 11:09:38 »
Wie kijkt AERO op 10500 BPS mee, is behoorlijk actief netwerk,  heel erg druk
Of wordt AERO al doorgezet op internet flightaware?
Offline Niek 898
« Reactie #13 Gepost op: 29 januari 2020, 19:40:23 »
Ik lees regelmatig de 10500 bps AERO kanalen op 1546,xx MHz op Alphasat mee: 2x GES Fucino en 4x GES Burum.
De berichten zijn voornamelijk ACARS berichten. Geen idee in hoeverre deze interessant zijn voor Flightaware (ik gebruik de site niet).
Als je op het ontvangen van vliegtuig posities via Inmarsat doelt: deze worden via de (burst) kanalen in de 3,6 GHz uitgezonden. De posties zijn dan bijvoorbeeld met JAERO en Planeplotter te plotten en door te zetten naar diverse sites.
opabert
« Reactie #14 Gepost op: 30 januari 2020, 12:31:45 »
Bedankt,
Welke antenne setup gebruik je?
