Auteur Topic: Nieuwe beta versie van SDR software HDSDR (november 2016)  (gelezen 6160 keer)
Offline Longmen
« Gepost op: 16 november 2016, 00:48:30 »
Nieuwe beta versie van SDR software HDSDR (1 november 2016)
Main features:
* separate large spectrum and waterfall display for input and output signals
* RF & AF spectrum and waterfall is optically zoomed to fit window width independently of FFT resolution bandwidth (RBW)
* flexible and efficient usage of the screen area from 640x480 (Netbooks) up to unlimited
* extreme low-speed waterfall - helpful for pattern noise detection or short wave condition monitoring
* AM, ECSS, FM, SSB and CW demodulation
* basic transmit (TX) functionality in modes SSB, AM, FM & CW
* I/Q modulated signal pair for the TX input signal (Microphone) is produced on the TX output
* squelch, noise reduction, noise blanker, adjustable band pass filter, anti-alias filter
* cautomatic notch filter and up to 10 manual adjustable notch filters
* record and playback RF, IF and AF WAV files with recording scheduler
* Frequency Manager for Eibi, Ham Bands, Radio Bands, User frequency lists
* DDE client for Ham Radio Deluxe, Orbitron, WXtrack, SatPC32 and Wisp (Howto)
* Omni-Rig support (CAT) to control additional hardware
* support for various hardware through Alberto's (I2PHD) ExtIO DLL interface
* ExtIO frequency options for IF-Adapter, Upconverter, Downconverter, Undersampling and calibration
* All HDSDR program options can be stored and loaded per "profile", to ease use of different receivers
* autocorrelation and cepstrum display for demodulated audio
* command line options "-as"(auto start), -fs" (full screen)
* "-swapsw" (swap spectrum/waterfall display), "-p profilename" (profiles)
http://www.hdsdr.de
Offline Rexodus
  • Zendamateur
  • PE5I
    • RX/TX raporten
Re: Nieuwe beta versie van SDR software HDSDR (november 2016)
« Reactie #1 Gepost op: 16 november 2016, 07:03:30 »
Wat is nieuw?  ???
QRO, einde probleem!
Offline Longmen
« Reactie #2 Gepost op: 16 november 2016, 09:22:35 »
Volgens Funkamateur http://www.funkamateur.de/nachrichtendetails/items/HDSDR2-75B1.html zijn de wijzigingen:
* Meer opname-opties;
* Ondersteuning voor 8-bit sampling-formaat;
* Ondersteuning voor 8K resolutie scherm (7680 × 4320 pixels);
* Advanced ExtIO opties;
* Bugfixes en kleine verbeteringen.
Offline Rexodus
  • Zendamateur
  • PE5I
    • RX/TX raporten
« Reactie #3 Gepost op: 16 november 2016, 11:14:30 »
TnX URL!
Helaas nog steeds de zelfde 80'er jaren / scherm verkwistende /zuurstok kleurtjes interface. Mgoed, het doet z'n werk en heeft wat dingetjes die andere niet  hebben.
Check vooral ook http://sdr-radio.com/v3_preview_downloads. Die gaat flink tekeer de laatste tijd (zover het al 1 coder is). Op de site staat al iets met sat-tracking. Is helaas nog niet in de software terug te vinden.. Ik kan niet wachten!
Gevoel voor humor heeft ie wel: "If you do not see the Satellites option then you must wait for a new preview kit to be available." ;)
73!
