Auteur Topic: Proscan 10.6 is uit  (gelezen 7457 keer)
HLB
Proscan 10.6 is uit
« Gepost op: 25 juni 2016, 07:06:36 »
Proscan 10.6 is uit. Nieuw is de "Resume Scan / Search function", waarmee je de scanner na een gewenst aantal seconden automatisch kan laten doorscannen of -zoeken.
Kan handig zijn, bijv. als de scanner tijdens het zoeken tegen een storing aan loopt. Geweldig dat Bob Aune de software steeds blijft verbeteren  ;D
Voor wie Proscan niet kennen:
-   Scanner Support - Supports 18 different Uniden models
-   Scanner Programming - Upload and download data to and from scanner.
-   Database - Full featured database with Find & Replace, Find Duplicates, Export and Imports data from ProScan database files, Uniden UASD database files, and RadioReference Web Service.
-   Source Client - Streams real time audio to Broadcastify, Icecast, and ShoutCast servers.  Source Client can replace Edcast/Oddcast and SimpleCast types of programs.  If you are a Broadcastify stream provider then the Source Client can be configured automatically.
-   Web Server - Servers a web page and serves real time audio and folders / files.  Audio and folders / files can be password protected.
-   Logger - Extensive logging with many options.
-   Remote Control Scanner Over IP - Control scanner remotely with streaming audio.
-   Recorder - No loss audio recorder.  Stereo or Mono.
-   Audio Flow Diagram - Shows audio flow along with the volume controls and level meters.
-   Band Scope - Great for testing antenna's and interference tracking
-   Control Channel Data Monitoring - Monitor the trunking control channel data.  Works with XT series scanners only.
-   Sessions Manager - Manages multiple instances of ProScan running on same computer.
-   Virtual Display - With keypad and knobs emulates the scanner front panel.
-   Serial Port - Auto Detect.
-   Test Tab - Bonus items such as sending commands to the scanner and viewing returned data from scanner.
-   Tabbed layout - For easy navigation.  Each tab contains a major feature.
http://www.proscan.org/
