Auteur Topic: Proscan 6.5  (gelezen 9825 keer)
HLB
Proscan 6.5
« Gepost op: 13 juli 2013, 19:09:58 »
Ik ben zoals sommigen zullen al jaren een fan van de Proscan software. Na een tijdlang op versie 6.0 te hebben gedraaid ben ik vanavond overgegaan naar 6.5. Ik ben altijd terughoudend met nieuwe versies want: if it ain't broke, don't fix it! :)
Maar de nieuwste versie van Bob Aune's supersoftware mag er zijn. Hieronder de bugfixes en verbeteringen sinds 6.0. Bijv. het sorteren van non-DMA scanners is handig en het kopieren van database gegevens tussen verschillende sessies ook!
ProScan What's New
Version 6.5  Newest Version 06/24/13
Added - DMA Database - P25 Band Plan.
Added - Non-DMA Database - Sort channels, scan, search, and the trunking grids.
Fixed - DMA Database - Uploading configuration was clearing the trunking channels lockout flag.
Version 6.4
Added - DMA Database - Trunking system selection box for changing the system type.
Added - Logging - UID Lookup file now can specify system.
Improved - Database - Find & Replace reworked with more options added. Find & Replace also works with the Logging and Recorder.
Improved - Database - Find Duplicates reworked with more options added.
Fixed - Source Client - Current Listeners count.
Fixed - Fixed - DMA Database - Lockout grids had various problems.
Version 6.3
Added - Web Server - Notch filter for filtering out the 50/60 Hz AC hum or any undesired frequency. The Notch Filter button is located in the Audio Control - Audio tab.
Added - Database - Now can Paste multiple times without clicking the Copy button everytime.
Added - Database - Sorting function now can sort individual systems and sort at the system, group, or channel levels.
Added - Database - DMA Scanners - Before uploading data to the scanner, a message will appear if a potential scanner memory limitation issue.
Added - XT Series Scanners - Option to turn off the C-CH Output when ProScan starts communications with the scanner.
Changed - Improved the Spectrum Analyzer display and performance.
Fixed - Recorder - The option "Delete < 2 Seconds Log Entries" only deleting the grid entries and not the files.
Fixed - Database - Drag & Drop and Copy & Paste between ProScan instances.
Fixed - Database - Importing P25 systems/sites from another ProScan database file wasn't setting the system type correctly.
Fixed - Database - XT Series Scanners - Default Band Coverage wasn't showing all bands.
Fixed - Database - XT Series P25 Scanners - RadioReference import wasn't showing the option "Import Control Channels Only" for P25 systems.
Fixed - Database - BCT15X - Close Call Settings VHF High 1 and VHF High 2 wasn't showing.
Version 6.2
Fixed - Fixed - Recorder - When a recording reached the "Maximum Recording Time" option, a new recording wasn't started.
Fixed - Fixed - Recorder - Remote Scanner Over IP in client mode garbled audio.
Version 6.1
Added - Scanner Over IP Server published servers can include the Country, State / Provice, & County / Region.
Fixed - Web Server - Non DMA scanners virtual keyboard numeric keys wasn't working on the web page.
Fixed - Scanner Over IP Server not allowing clients to connect in some cases depending on the computer region settings.
Fixed - Frequency Tune direct entry and band Scope "Tune Scanner To Marker" button was changing the Close Call Settings.
PD1EU
Re: Proscan 6.5
« Reactie #1 Gepost op: 13 juli 2013, 21:54:13 »
Ook deze versie geeft vastlopers op mijn Windows-7 notebook. Als daar nu eens een fix voor komt!
HLB
Re: Proscan 6.5
« Reactie #2 Gepost op: 13 juli 2013, 23:12:35 »
Mm da's balen. Jij had daarover toch contact gehad met Bob Aune?
PD1EU
Re: Proscan 6.5
« Reactie #3 Gepost op: 13 juli 2013, 23:17:51 »
Bob wist het ook niet meer. Einde e-mail contact.
PD1EU
Re: Proscan 6.5
« Reactie #4 Gepost op: 14 juli 2013, 02:18:36 »
De eindconclusie van Bob was,
"I've seen two other problems similar to what you described in all the years and it turned out to be the video driver?
If it's not the driver then I don't know what it could be."
Offline Eilandgast
Re: Proscan 6.5
« Reactie #5 Gepost op: 28 augustus 2013, 19:49:38 »
Versie 6.6 draait bij mij ook al weer als een zonnetje.
ubc220xlt, bcd396xt, 60CSx
