Auteur Topic: CubeSats lancering: 02-07-2012 om 07:40 UT  (gelezen 8624 keer)
Offline Sigint
  • COMSPEC
« Gepost op: 2 augustus 2012, 01:03:39 »
On August 2, 2012 at 07:40 UT an Atlas V rocket is planned to launch a combination of 11 satellites from Vandenberg Air Force Base in California for the US Government and NASA ELaNa university CubeSats.
CINEMA:
Downlinks for engineering telemetry and command are in the 2400-2450 MHz range; Science telemetry is in 2200-2300 MHz range.
CSSWE:
Downlink 437.345 MHz, 9k6 with AX25
CP5 CubeSat – CalPoly:
Downlink 437.525 MHz, GFSK, AX.25
US Government Payloads:
First CubeSat to deploy 2.4 GHz Dish Antenna. WiFi transmitter will transmit on 2425.0 MHz with 1 watt of output power.
Downlink 437.600 MHz AX25 1200 bps beacon every 10 second and a spread spectrum two-way link elsewhere in the 70cm band.
Live coverage by ULA
http://www.ulalaunch.com/site/pages/Multimedia_Webcast.shtml
http://www.timester.com/verpais.cgi?iso=NL
Bye.
Sigint
"Monitoring till 12 GHz"
Offline Sigint
  • COMSPEC
Re: CubeSats lancering: 02-07-2012 om 07:40 UT
« Reactie #1 Gepost op: 2 augustus 2012, 08:42:52 »
Status : On Hold-09.42L.T.
http://www.livestream.com/spaceflightnow/
Bye.
Sigint
Offline Sigint
  • COMSPEC
« Reactie #2 Gepost op: 2 augustus 2012, 09:19:44 »
Lancering uitgesteld vanwege technisch probleem. :(
Bye.
Sigint
Offline Sigint
  • COMSPEC
« Reactie #3 Gepost op: 26 augustus 2012, 01:00:36 »
Date/Launch Time/Site: Thursday, Aug. 30, 2012, from Space Launch Complex-41 at Cape Canaveral Air Force Station, Fla. The 20-minute launch window opens at 4:05 a.m. EDT.
Offline PE7EB
  • QTH Alkmaar JO22jp
« Reactie #4 Gepost op: 26 augustus 2012, 12:42:55 »
Wellicht handig om ook je bron even te vermelden Sigint :)
Waar ik me trouwens nog steeds over verbaas is dat zelfs organisaties als NASA nog steeds werken met bijvoorbeeld EDT in plaats van wereldwijd bekende en begrijpelijke tijden in GMT.
73 es gud dx de eric pe7eb k
Offline Sigint
  • COMSPEC
« Reactie #5 Gepost op: 26 augustus 2012, 13:19:05 »
Die staat in de begin posting. ;D
Bye.
Sigint
