Auteur Topic: Shuttle vlucht STS-127  (gelezen 11952 keer)
Offline counterstrike
« Gepost op: 13 juni 2009, 00:56:09 »
STS-127
Vandaag, zaterdag 13 juni 2009, wordt Space Shuttle vlucht STS-127 gelanceerd. Er is een goede kans dat deze in Nederland kan worden ontvangen in zijn eerste baan om de aarde op 259.7000 in de AM mode.
Kijk voor meer info en frequenties op: http://home.wanadoo.nl/psdedeugd/index.html
Peter
Offline Hanso
Re: Shuttle vlucht STS-127
« Reactie #1 Gepost op: 13 juni 2009, 10:31:04 »
Ter info.
STS-127 lancering uitgesteld voor minimaal 96 uur.
Zie onderstaand bericht Nasa.
"Endeavour Launch Delayed
At NASA's Kennedy Space Center in Florida, the launch of space shuttle Endeavour's STS-127 mission to the International Space Station is on hold due to a leak associated with the gaseous hydrogen venting system outside the external fuel tank. The system is used to carry excess hydrogen safely away from the launch pad. At 12:26 a.m. EDT Saturday, June 13, shuttle managers officially scrubbed the launch for at least 96 hours."
Hans
Offline Warlord32
« Reactie #2 Gepost op: 13 juni 2009, 13:45:08 »
Gaseous Hydrogen Leak Postpones Endeavour's Saturday Launch, Repair Options Evaluated
Sat, 13 Jun 2009 08:55:12 AM GMT+0200
The launch of space shuttle Endeavour's STS-127 mission to the International Space Station is on hold due to a leak associated with the gaseous hydrogen venting system outside the external fuel tank. The system is used to carry excess hydrogen safely away from the launch pad at NASA's Kennedy Space Center in Florida. At 12:26 a.m. EDT Saturday, managers officially scrubbed the launch for at least 96 hours.
The earliest the shuttle could be ready for liftoff is June 17, however there is a range conflict on that date with the scheduled launch of the Lunar Reconnaissance Orbiter/Lunar Crater Observation and Sensing Satellite from Cape Canaveral Air Force Station, Fla.
Mission managers will hold a meeting at 2 p.m. Sunday to discuss the repair options and Endeavour's launch attempt opportunities. A news conference will follow the meeting's conclusion and will air live on NASA Television and the agency Web site.
Offline weddy
« Reactie #3 Gepost op: 15 juni 2009, 19:05:13 »
Space Shuttle Endeavour's STS-127 Launch Set for June 17
Mon, 15 Jun 2009 07:27:47 PM UTC+0200
NASA managers have scheduled the next launch attempt of space shuttle Endeavour's STS-127 mission for 5:40 a.m. EDT on Wednesday, June 17.
Endeavour's planned June 13 liftoff was postponed because of a leak associated with the gaseous hydrogen venting system outside the shuttle's external fuel tank. The system is used to carry excess hydrogen safely away from the launch pad.
As a result, the Lunar Reconnaissance Orbiter, or LRO, and Lunar Crater Observation and Sensing Satellite, or LCROSS, are set to lift off together aboard an Atlas V rocket on Thursday, June 18. That launch was moved to June 18 to accommodate Endeavour's June 17 liftoff.
Groetjes
Edwin
Div ontvangers van 25mhz  tot 10ghz zowel atv als breedband
Antennes : inverted v voor hf , x5000 voor 2mtr 70cm 23cm , dl6wu yagi 23cm band , dl6wu yagi 13 cm band , log per 800mhz tot 6ghz ,  lnb met 20db hoorn voor 10ghz
Offline weddy
« Reactie #4 Gepost op: 17 juni 2009, 11:11:14 »
Hydrogen Leak Prevents STS-127 Launch
Wed, 17 Jun 2009 10:03:28 AM UTC+0200
Space shuttle Endeavour's STS-127 launch today was officially scrubbed at 1:55 a.m. EDT when the same type of gaseous hydrogen leak was detected at the Ground Umbilical Carrier Plate, or GUCP. This is the same location where a similar leak resulted in a launch scrub on June 13.
"We're going to step back and figure out what the problem is and go fix it," said Deputy Space Shuttle Program Manager LeRoy Cain during a briefing afterward. "Once we get it fixed and we're confident that we have a solution that's going to work and allow us to go fly safely, then we'll proceed forward."
Teams followed the same repair method as they did for the GUCP leak encountered during the STS-119 countdown. The STS-119 and STS-127 leaks will both be evaluated in order to determine the cause. Data collected during fueling is expected to help the troubleshooting effort.
Endeavour's next launch attempt for its STS-127 mission is targeted for July 11 at 7:39 p.m. EDT.
« Reactie #5 Gepost op: 11 juli 2009, 17:01:23 »
Voor meer info en de TLE gegevens: http://home.wanadoo.nl/psdedeugd/Lanceringen.html
« Reactie #6 Gepost op: 11 juli 2009, 17:47:26 »
Citaat van: "counterstrike"
23.39 UTC / 21.39 Nederlandse tijd.
Huh?
« Reactie #7 Gepost op: 11 juli 2009, 19:11:54 »
Citaat van: "Discriminator"
Huh?
Stond inderdaad 1x fout vermeld.
(Als je niks doet kun je ook geen fouten maken zei ooit een wijze oosterling  ;) )
« Reactie #8 Gepost op: 11 juli 2009, 19:12:40 »
Ivm met de weersomstandigheden is de lancering uitgesteld ..........
Peter
Offline Freebird
« Reactie #9 Gepost op: 11 juli 2009, 21:05:33 »
The launch of space shuttle Endeavour was postponed until Sunday evening so engineers could evaluate the spacecraft's myriad systems following 11 lightning strikes in the Launch Complex 39A area.
None of the strikes hit the shuttle or its external tank and solid rocket boosters, but there were strikes to the lightning mast and water tower. The launch pad is equipped with a lightning protection system of wires that is intended to steer bolts away from the shuttle.
"We've seen nothing so far that shows anything affected any of the systems," said Mike Moses, chairman of the pre-launch Mission Management Team.
Two of the strikes were strong enough to trigger an evaluation by engineers just to make sure all of Endeavour's systems are ready for flight. Although early evaluations showed no problems, engineers wanted more time to make sure they have checked everything correctly.
"We need to be 100 percent confident that we have a good system across the board," Moses said.
The launch time for Sunday is 7:13 p.m. EDT. The weather forecast calls for a 60 percent chance of acceptable conditions.
UBC125XLT - Diamond RH707 - D777, UBC280XLT
« Reactie #10 Gepost op: 11 juli 2009, 21:27:45 »
Inderdaad
Offline Freebird
« Reactie #11 Gepost op: 12 juli 2009, 21:36:16 »
Allez we zitten weer klaar, +-2.30 op de klok tot de lancering.
http://www.hearsat.org/irc hier ook weer een gezellige drukte.
Teamspeak draait ook weer. uhf-satcom.com paswoord is satcom
Offline Freebird
« Reactie #12 Gepost op: 12 juli 2009, 21:42:13 »
261.575 wolfden is ook aan de radio check.
Nasa Tv is up.
http://www.nasa.gov/multimedia/nasatv/
Offline luistervink
« Reactie #13 Gepost op: 12 juli 2009, 22:21:20 »
Citaat van: Freebird
en hier is een van de geluidsfragmenten van zojuist .:  http://rapidshare.com/files/255110461/wolfden.wav
gr.
luistervink
Icom pcr1500;2 Kenwood R5000;RFT EGD01,RFT EKD300,EZ111,Yupiteru7100;Rfsystems 20mlongw,avv01k,Sp-3,Log per milsat;code3;;inmarsat std-c decoder 80cm dish op 15,5 w;radarbox,ubc800xlt
« Reactie #14 Gepost op: 12 juli 2009, 22:46:12 »
Voor de liefhebbers: HF 5711 USB recovery schepen.
