Auteur Topic: CAS Notams  (gelezen 4182 keer)
HLB
CAS Notams
« Gepost op: 11 januari 2009, 07:56:24 »
EBBU   BRUSSELS (ACC-FIC)
M0087/09 - DUE TO CAS EXERCISE 'POPPY 02 AND DEPLOYED FALCON', AIRSPACE LIMITATIONS CAN BE IMPOSED WITHIN THE EBTRASA (TRA SOUTH ALPHA) UP TO FL150. PARTICIPATING A/C HAVE PRIORITY. AIRSPACE LIMITATIONS CAN BE CHECKED WITH ATCC DATCO (+32 9 389 2555) OR BELGA RADAR. 4500FT AMSL - FL150, JAN 26 1200-1600, 27 0800-2000, 28 0800-1100 1200-1900, 29 0800-1100 1200-1600 AND JAN 30 0800-1100, 26 JAN 12:00 2009 UNTIL 30 JAN 11:00 2009. CREATED: 07 JAN 12:19 2009
M0086/09 - DUE TO CAS EXERCISE 'POPPY 02' HIGH DENSITY MILITARY TRAFFIC UP TO 15NM AROUND PSN 500049N 0053136E. 250FT AGL - 4500FT AMSL, JAN 26 1230-1600, 27-29 0830-1100 1230-1600 AND JAN 30 0830-1100, 26 JAN 12:30 2009 UNTIL 30 JAN 11:00 2009. CREATED: 07 JAN 12:12 2009
M0085/09 - DANGER AREA EBD33 ACTIVATED FOR CAS 'POPPY 02'. 250FT AGL - 4500FT AMSL, JAN 26 1230-1600, 27-29 0830-1100 1230-1600 AND JAN 30 0830-1100, 26 JAN 12:30 2009 UNTIL 30 JAN 11:00 2009. CREATED: 07 JAN 12:08 2009 M4621/08 - DUE TO CAS EX 'POPPY 01', AIRSPACE LIMITATIONS CAN BE IMPOSED WITHIN THE EBTRASA (TRA SOUTH ALPHA) UP TO FL150. PARTICIPATING A/C HAVE PRIORITY. AIRSPACE LIMITATIONS CAN BE CHECKED WITH ATCC DATCO (+32 9 389 2555) OR BELGA RADAR. 4500FT AMSL - FL150, JAN 12 1200-1600, 13-15 0800-1100 1200-1600 AND JAN 16 0800-1100, 12 JAN 12:00 2009 UNTIL 16 JAN 11:00 2009. CREATED: 16 DEC 09:24 2008
M4620/08 - DUE TO CAS EXERCISE 'POPPY 01' HIGH DENSITY MILITARY TRAFFIC UP TO 13NM AROUND PSN 500910N 0052711E. 250FT AGL - 4500FT AMSL, JAN 12 1230-1600, 13-15 0830-1100 1230-1600 AND JAN 16 0830-1100, 12 JAN 12:30 2009 UNTIL 16 JAN 11:00 2009. CREATED: 16 DEC 09:20 2008
M4619/08 - DANGER AREA EBD35 ACTIVATED FOR CAS 'POPPY 01'. 250FT AGL - 4500FT AMSL, JAN 12 1230-1600, 13-15 0830-1100 1230-1600 AND JAN 16 0830-1100, 12 JAN 12:30 2009 UNTIL 16 JAN 11:00 2009. CREATED: 16 DEC 09:16 2008
Offline rik56
Re: CAS Notams
« Reactie #1 Gepost op: 11 januari 2009, 09:27:01 »
Citaat van: "HLB"
Beste,
Met belangstelling uw topic gelezen.
Kan u of iemand anders me vertellen hoe ik deze coordinaten kan omzetten in een plaats?
Groeten uit de stille en wit besneeuwde Kempen
Rik
HLB
Re: CAS Notams
« Reactie #2 Gepost op: 11 januari 2009, 09:30:30 »
Je kunt de co-ordinaten in Google Earth ingeven en vervolgens "markers" zetten teneinde het oefengebied in beeld te krijgen.
Het is ff vogelen maar ik geloof dat dit het correcte plaatje is met 50 00 49N 005 31 36E als ingave.
Offline rik56
Re: CAS Notams
« Reactie #3 Gepost op: 11 januari 2009, 09:52:52 »
Citaat van: "HLB"
Heb geprobeerd om ze zoals ze daar staan in te geven in Google maps maar dit geeft geen resultaat, heb het ooit klaargekregen maar was dacht ik in een ander formaat.
Toch bedankt voor de reactie.
Rik
Ben er ondertussen uit...... dankzij uw bijgevoegde foto tot de conclusie gekomen dat mijn spaties niet juist stonden
 :oops:
HLB
Re: CAS Notams
« Reactie #4 Gepost op: 11 januari 2009, 09:58:53 »
Citaat van: "rik56"
Ben er ondertussen uit...... dankzij uw bijgevoegde foto tot de conclusie gekomen dat mijn spaties niet juist stonden:
In Britse notams zijn ze vaak zo vriendelijk om naast de co-ordinaten een plaatsnaam in de buurt te vermelden. Zodoende kun je ff checken of je goed zit.
