Auteur Topic: Hurricane Net: Gustav  (gelezen 9504 keer)
Offline BlackBox
« Gepost op: 31 augustus 2008, 08:18:47 »
Voor iedereen die de HF nog niet heeft bij staan, Gustav is onderweg naar New Orleans, luister naar 14.325 USB during daylight hours
Tracking van de Hurricane: http://www.ibiseye.com
TV streams
http://www.maroonspoon.com/wx/gustav.html
Amateur Radio Communications Streams
http://www.radioreference.com:8000/HURRWATCHNET.m3u - Single Sideband (SSB) Hurricane Watch Net Stream. (Subject to propagation and signal-strength variables.) Stream will only be active when reception quality is usable AND the "net" is active and not covered by noise or Foreign Broadcast Interference at night. Generally, the Net closes down from 10 PM through 1 PM the folowing day when the storm is off-shore. That is the case today.
http://kc4qlp.dyndns.org:8082/ - The *KC4QLP-C* Echolink conference server, node 290251
http://www.w2lie.net - Click Listen Live -> Ham Radio -> VOIPWXNET to listen. A relay of the above stream
Good monitoring!
Frequency Monitor Centre
Offline BlackBox
Re: Hurricane Net: Gustav
« Reactie #1 Gepost op: 31 augustus 2008, 08:19:23 »
Er zijn slechts 5 URL's toegestaan per bericht, hier het vervolg:
Louisiana Online Communications Streams
http://www.radioreference.com:8000/nola.mp3.m3u - Streaming from New Orleans. Covering LATIE interop and emergency management channels
Texas Online Communications Streams
http://www.radioreference.com:8000/satx.mp3 - San Antonio EVAC operations
http://tx.scanamerica.us/playlists/tx/g ... 167415.asx
Good monitoring!
Offline BlackBox
« Reactie #2 Gepost op: 31 augustus 2008, 08:45:25 »
NOAA flight tracking:
http://flightaware.com/live/airport/KMCF
NOAA P-3's vanuit MacDill die hun missies vliegen.
Klik op een specifiek kist: NOAA 42,43 or G-4 49.
Good monitoring!
Offline BlackBox
« Reactie #3 Gepost op: 31 augustus 2008, 08:52:45 »
Verkeerssituatie rond "Mobile", de kust in Alabama: http://www.dot.state.al.us/internetdocs ... alist.aspx
Good monitoring!
Offline bubo bubo
« Reactie #4 Gepost op: 31 augustus 2008, 09:55:43 »
Een actuele lijst van HF frequenties die rondom hurricane Gustav zouden kunnen worden gebruikt is te vinden op:
http://mt-utility.blogspot.com/
(Kijk op de datum van 30 augustus 2008).
Boven genoemd blog en volgende:
http://mt-milcom.blogspot.com/
geven actuele overzichten van gehoorde HF frequenties. De genoemde frequenties zijn in de VS ontvangen. Door propagatie omstandigheden is ontvangst in onze regio niet altijd mogelijk.
Zoals je kunt zien, blijkt HF radio tijdens natuur rampen nog steeds een belangrijk communicatie medium te zijn.
Bubo bubo
Offline BlackBox
« Reactie #5 Gepost op: 31 augustus 2008, 20:03:34 »
In Austin TX is het commando centrum ingericht t.b.v. Gustav, G.W.Bush zal hier naar toe afreizen en later zijn reis vervolgen naar San Antonio
Linkje: http://www.ci.austin.tx.us/oem/eoc.htm
Good monitoring!
Offline John R
« Reactie #6 Gepost op: 31 augustus 2008, 20:38:32 »
ik zag of Fox dat er 50000 man National Gards opgetrommeld worden. Mogelijk dat daar ook nog een online scanner voor is te vinden.
Ik ben blij dat ik daar niet zit, maar vind het wel zeer interessant om te beluisteren. Heb de Yeasu FRG 100 al op 14.325 afgesteld, mogelijk pik ik weer wat communicatie op.
groeten...  John R
Offline BlackBox
« Reactie #7 Gepost op: 31 augustus 2008, 21:08:05 »
Ik hoor al National Guard met call signs als BULLDOG, TIGER, HAWK, STEEL op de New Orleans stream en allerlei adressen die in opdracht van ELC Dispatch worden bezocht. Verder net een Chinook en 2 Heuy (UH-1) gehoord c/s EAGLE.
Good monitoring!
Offline BlackBox
« Reactie #8 Gepost op: 31 augustus 2008, 21:49:56 »
Het wordt al aardig stil op de wegen rond New Orleans: http://www.watchfox.com/watchfox29/trafficpage.html
Good monitoring!
Offline counterstrike
« Reactie #9 Gepost op: 1 september 2008, 23:39:19 »
Citaat van: "BlackBox"
Net als de storm:
  124     Teletekst di 02 sep
    Grootste gevaar Gustav geweken
 ` Aan de Amerikaanse zuidkust is het
 grootste gevaar van de orkaan Gustav
 geweken.Hij is nu nog een zwakke orkaan
 met windsnelheden tot 144 km/u en valt
 daarmee niet meer in categorie twee.
 De dijken bij New Orleans hebben het
 tot nu toe gehouden.Drie jaar geleden
 kwam New Orleans grotendeels blank te
 staan door dijkdoorbraken.Toen raasde
 de orkaan Katrina door Louisiana.Toch
 waarschuwen deskundigen dat het gevaar
 voor doorbraken nog niet is geweken.
 Een automobiliste is omgekomen toen ze
 tussen Baton Rouge en New Orleans op
 een omgewaaide boom reed.Twee miljoen
 mensen zijn ge ėvacueerd.
 volgende  nieuws  weer&verkeer  sport
Storm in een glas water, stilte voor de storm ?
groeten,
Peter
Offline hamclassics
« Reactie #10 Gepost op: 2 september 2008, 00:30:43 »
voor de late vogels... volop actie op de stream bij texas online en dan de radioreference link
En nog heel veel meer :)
« Reactie #11 Gepost op: 7 september 2008, 19:41:51 »
Nog even een aanvulling, vandaag las ik in een nieuwsgroep dat de zogenaamde Hurricane Hunters van het NOAA regelmatig een positierapport aan de verkeersleiding in New York doorgeven op 11330 KHz in de USB mode.
De frequentie maakt deel uit van de zogenaamde Caribbean 2 regio, afhankelijk van de propagatie kunnen er ook andere frequenties gebruikt worden.
De frequenties die in gebruik zijn in deze regio:
3455
5520
6586
8846
11330
17907
De callsign die hij meerdere malen heeft waargenomen is:
NOAA 49 (Gulfstream G-IV-SP, NOAA Hurricane Hunter, MacDill AFB)
Succes,
Peter
