Auteur Topic: Discussie P2000 GGD/GHOR/RAV Kennemerland  (gelezen 211107 keer)
Re: Discussie P2000 GGD/GHOR/RAV Kennemerland
« Reactie #60 Gepost op: 14 april 2008, 09:33:16 »
Citaat van: "Rolf"
90125 HS-GHOR
90124 RGF
Bij 90124 zie ik steeds de volgende 4 codes terugkeren;
012710604:30:12 01-01-08  90124 0235319191
012710704:39:03 01-01-08  90124 0235319191
012710504:40:08 01-01-08  90124 0235319191
012710415:30:10 16-02-08  90124 0235319191
Bij 90125 zie ik steeds de volgende 2 codes terugkeren;
012718711:31:27 25-03-08  90125 0235511367
012718618:53:43 13-04-08  90125 0235511367
« Reactie #61 Gepost op: 14 april 2008, 09:37:40 »
Citaat van: "Rolf"
94305 proefalarm O&V Noord
94405 proefalarm O&V Zuid
O&V Zuid
012728819:06:17 02-04-08  94405
012746619:03:28 02-04-08  94405
012747019:01:52 02-04-08  94405
012765318:59:48 26-03-08  94405
012765418:58:47 26-03-08  94405
012765518:58:47 26-03-08  94405
012765818:58:47 26-03-08  94405
012765918:59:56 26-03-08  94405
012766019:01:03 26-03-08  94405
012766118:58:47 26-03-08  94405
012766418:58:47 26-03-08  94405
012766519:02:57 26-03-08  94405
012766619:02:51 09-04-08  94405
012766718:59:44 26-03-08  94405
012766818:59:13 02-04-08  94405
012766919:02:51 09-04-08  94405
012767018:59:13 02-04-08  94405
O&V Noord
012728818:59:22 26-03-08  94305
012746019:03:05 26-03-08  94305
012746118:59:39 26-03-08  94305
012746219:01:49 02-04-08  94305
012746319:00:03 02-04-08  94305
012746619:03:09 09-04-08  94305
012746818:59:49 02-04-08  94305
012746919:04:48 02-04-08  94305
012747219:03:18 02-04-08  94305
012747418:59:21 26-03-08  94305
012747519:03:33 26-03-08  94305
012747919:00:24 26-03-08  94305
012748118:59:39 26-03-08  94305
012748319:03:44 26-03-08  94305
012748719:00:01 09-04-08 94305
012748819:02:22 26-03-08  94305
012749219:01:24 02-04-08  94305
012749318:59:20 26-03-08  94305
012749419:00:45 02-04-08  94305
012749618:59:37 26-03-08  94305
012749818:59:37 26-03-08  94305
012749919:00:14 26-03-08  94305
012760118:59:59 09-04-08  94305
012760219:01:55 09-04-08  94305
012760318:59:19 09-04-08  94305
012760419:01:55 09-04-08  94305
012760518:59:21 09-04-08  94305
012760619:01:00 09-04-08  94305
012760819:01:30 09-04-08  94305
012761018:59:22 09-04-08  94305
012761119:01:55 09-04-08  94305
012761218:59:22 09-04-08  94305
012761419:03:34 09-04-08  94305
012761518:59:59 09-04-08  94305
012761619:01:52 09-04-08  94305
012765718:59:22 26-03-08  94305
012779519:05:14 02-04-08  94305
De volgende 2 codes komen in beide gebieden voor;
01272880127466
012728810:27:37 26-12-07  proefalarm
012728819:34:03 14-02-08  90234
012728819:34:18 21-02-08  94225
012728818:29:12 12-03-08  94125
012746608:38:21 01-01-08  90130
012746618:30:16 20-02-08  90134
012746618:29:12 12-03-08  94125
012746618:29:22 19-03-08  94225
Offline Jor
« Reactie #62 Gepost op: 14 april 2008, 13:19:58 »
Het telefoonnummer 023-5511367 is van de communicator. Bij uitval of onderhoud van P2000 word je door dit nummer gebeld.
« Reactie #63 Gepost op: 14 april 2008, 13:22:15 »
Citaat van: "Jor"
Het ging mij alleen even om die 2 CAPcodes  ;)
Offline RS
« Reactie #64 Gepost op: 14 april 2008, 14:41:26 »
90125 HS-GHOR
Bij deze twee caps treedt ook een piek aan verschillende scenarionummers op. Deit scenearionummer komt ook voor bij 1270881.
Offline RS
« Reactie #65 Gepost op: 14 april 2008, 14:43:34 »
Citaat van: "RS"
90125 HS-GHOR
Bij deze twee caps treedt ook een piek aan verschillende scenarionummers op. 270881 komt ook voor met scenarionummer 90125
« Reactie #66 Gepost op: 14 april 2008, 14:50:35 »
Citaat van: "RS"
Jij bedoelt 0127881. Die had ik ook een paar keer gezien ja. Maar ook weer met diverse andere scenario's .
Offline Arle
« Reactie #67 Gepost op: 14 april 2008, 19:29:05 »
Citaat van: "RS"
Logischerwijs zou ik zeggen dat het bijvoorbeeld leidinggevende zijn van de O&V.  ;)
Arlé
Rolf
« Reactie #68 Gepost op: 15 april 2008, 00:51:32 »
Het scenario code 90125 is de HS-GHOR. De HS-GHOR wordt al gealarmeerd bij een GRIP 1. Dus elke scenario van GRIP 1 of hoger staat deze er dus tussen. De bijbehorende capcode is van een persoon die alleen tijdens harde piket zijn pager gebruikt. Anders gaat de alarmering via de telefoon bijvoorbeeld.
En heel toevallig is de capcode verbonden aan een OvD-G/ HS-GHOR/ teamleider. Dan kan je natuurlijk wel begrijpen, dat er veel denkbare scenario's zijn waar deze persoon bij gealarmeerd zou kunnen worden.
De scenario code 90124 is de RGF. Deze komt pas bij GRIP 2 of hoger.
« Reactie #69 Gepost op: 15 april 2008, 02:59:20 »
Van vriend Rolf zag ik op een ander forum een bericht waarin hij iets wist te vertellen over een reeks codes voor de CPA centralisten. Hiervan dacht ik altijd dat het de pool was van de Vrijwillig Brandweer Centralisten.
Het gaat om de reeks 0127020 - 0127042.
En ik kijk zojuist even in de lijst met laatste meldingen van de CPA en het is of de duvel er mee speelde.
012703322:36:10 14-04-08 gaarne telf kontakt cpa
012703522:40:34 14-04-08 Gaarne telf kontakt cpa ivm ziekte dagdienst van morgen
Niet zo verwonderlijk ook eigenlijk want van 0127021 en 0127039 wist ik al dat het CPA centralisten waren.
Rolf
« Reactie #70 Gepost op: 15 april 2008, 04:24:07 »
127039 is de groepspiket code. Alleen de dd piket centralist hoeft daarop te reageren.
Offline RS
« Reactie #71 Gepost op: 15 april 2008, 14:23:37 »
Citaat van: "Rolf"
Waar ik eigenlijk wel nieuwsgierig naar ben is, of er nou enige logische opbouw zit in die scenarionummers of helemaal niet?
Rolf
« Reactie #72 Gepost op: 16 april 2008, 01:21:05 »
Citaat van: "RS"
Ja, bijvoorbeeld de scenario's
**401 en **801 => GRIP 1
**402 en **802 => GRIP 2
**423 en **823 => opschaling van GRIP 2 naar GRIP 3
**403 en **803 => GRIP 3
**434 en **824 => opschaling van GRIP 3 naar GRIP 4
**404 en **804 => GRIP 4
De eerste twee cijfers staan voor de plaats alwaar de GRIP-procedure plaats vindt. Ik denk dat je er met een beetje sleutelen wel uit komt, welke gemeente welke codering heeft.
Vervolgens is de **5** voor alle gemeentelijke processen in de opgeschaalde processen.
90*** staat voor regionale alarmeringen, daar zijn een paar uitzonderingen op, maar door de bank genomen klopt dat aardig.
« Reactie #73 Gepost op: 16 april 2008, 02:32:57 »
Ik ga daar overdag thuis eens mijn hoofd over breken. Nu hier op het werk eerst de ellende van de aanrijding bij Halfweg weg zien te werken.
Rolf
« Reactie #74 Gepost op: 16 april 2008, 02:42:57 »
Ik ben al een tijdje klaar met dat incident. Succes
