Auteur Topic: 434.4125  (gelezen 19903 keer)
Re: 434.4125
« Reactie #30 Gepost op: 7 mei 2008, 19:52:47 »
Trouwens, hebben Praxis/McD/whatever hier primair of secundair gebruik? De frequenties liggen namelijk midden in de 70cm amateurband (430-440MHz)... Het Nationaal Frequentieplan van AT zegt voor 432-436 "/mob/ 4 Mobiele communicatie, SRD. 5.138. 5.282. Geen vergunning vereist voor SRD."
Citaat van: "5.138"
The following bands:
6765-6795 kHz (centre frequency 6780 kHz),
433.05-434.79 MHz (centre frequency 433.92 MHz) in Region 1 except in the
countries mentioned in No. 5.280,
61-61.5 GHz (centre frequency 61.25 GHz),
122-123 GHz (centre frequency 122.5 GHz), and
244-246 GHz (centre frequency 245 GHz)
74
are designated for industrial, scientific and medical (ISM) applications. The use of these
frequency bands for ISM applications shall be subject to special authorization by the
administration concerned, in agreement with other administrations whose
radiocommunication services might be affected. In applying this provision, administrations
shall have due regard to the latest relevant ITU-R Recommendations.
Citaat van: "5.282"
In the bands 435-438 MHz, 1260-1270 MHz, 2400-2450 MHz, 3400-3410 MHz (in
Regions 2 and 3 only) and 5650-5670 MHz, the amateur-satellite service may operate
subject to not causing harmful interference to other services operating in accordance with
the Table (see No. 5.43). Administrations authorizing such use shall ensure that any
harmful interference caused by emissions from a station in the amateur-satellite service is
immediately eliminated in accordance with the provisions of No. 25.11. The use of the
bands 1260-1270 MHz and 5650-5670 MHz by the amateur-satellite service is limited to
the Earth-to-space direction.
Freubeljoep
Re: 434.4125
« Reactie #31 Gepost op: 10 december 2008, 18:08:27 »
Hoi allemaal,
Ook de praxis in Venray gebruikt 434.4125Mhz en 433.2125 Mhz zelfde principe TQ97.4
