Auteur Topic: PDW through VirtualBox  (gelezen 9276 keer)
Offline SBS01
« Gepost op: 30 november 2020, 17:59:24 »
Hi
I've been trying to run PDW through Virtualbox with an XP SP3 VM. While everything installs correctly and the slicer install seems to settle in correctly on the right COM port,  i cannot get the application to  get data from the the slicer. I confirmed that the COM port is working using another  device that is controlled via the COM port and it was flawless.
Has anyone had any success using a VM to run this program?
Thanks
Re: PDW through VirtualBox
« Reactie #1 Gepost op: 30 november 2020, 20:09:04 »
What kind of 'slicer' do you use?
Offline SBS01
« Reactie #2 Gepost op: 30 november 2020, 20:42:32 »
Yours  :)
« Reactie #3 Gepost op: 30 november 2020, 20:46:31 »
2-level, 4-level, RS-232, USB?
Offline SBS01
« Reactie #4 Gepost op: 30 november 2020, 21:14:08 »
Sorry, 4-Level
Offline SBS01
« Reactie #5 Gepost op: 30 november 2020, 21:24:41 »
Image of config: https://ibb.co/xMhvBDG
« Reactie #6 Gepost op: 30 november 2020, 21:35:31 »
For the 2 and 4-level interfaces, PDW needs direct hardware access to the serial port, since the port is used in a non-standard way. I.e. it doesn't observe the standard RS-232 protocol.
Using a virtual machine introduces a hardware abstraction layer, where direct access to the serial port hardware is not possible. So, it's not going to work.
Offline SBS01
« Reactie #7 Gepost op: 30 november 2020, 21:48:01 »
Thanks for this information, I guess I'll be building a little XP PC for this monitoring.  :)
