Auteur Topic: FAC exers East Anglia  (gelezen 3680 keer)
HLB
« Gepost op: 6 december 2014, 16:59:48 »
H6081/14 - FORWARD AIR CTL EXER. FAST JET ACFT WILL CONDUCT HIGH ENERGY MANOEUVRES WI 5NM RADIUS 525203N 0001015E (HOLBEACH). MAJORITY ACT  AT 2000FT AGL AND BLW. ACFT MAY OPR OUTSIDE AREA AND MAY NOT COMPLY WITH THE RULES OF THE AIR. ACFT SHALL REMAIN CLR OF CONTROLLED  AIRSPACE. CREWS WISHING TO TRANSIT AREA SHOULD CTC HATCHET CONTROL ON 265.625MHZ, 266.700MHZ OR VHF 149.550MHZ. OPS CTC 07771 833953 OR 07827937701. 14-12-0058/OPS 2. SFC - 24000FT AMSL, 0800-1500, 11 DEC 08:00 2014 UNTIL 12 DEC 15:00 2014. CREATED: 04 DEC 15:45 2014
H6080/14 - FORWARD AIR CTL EXER. FAST JET ACFT WILL CONDUCT HIGH ENERGY MANOEUVRES WI 5NM RADIUS 525049N 0004554E (SCULTHORPE). MAJORITY ACT AT 2000FT AGL AND BLW. ACFT MAY OPR OUTSIDE AREA AND MAY NOT COMPLY WITH THE RULES OF THE AIR.  ACFT SHALL REMAIN CLR OF CONTROLLED AIRSPACE. CREWS WISHING TO TRANSIT AREA SHOULD CTC HATCHET CONTROL ON 265.625MHZ, 266.700MHZ OR VHF 149.550MHZ. OPS CTC 07771 833953 OR 07827937701. 14-12-0057/OPS 2. SFC - 24000FT AMSL, 08-11 0800-2300, 12 0800-1500, 08 DEC 08:00 2014 UNTIL 12 DEC 15:00 2014. CREATED: 04 DEC 15:43 2014
H6079/14 - FORWARD AIR CTL EXER. FAST JET ACFT WILL CONDUCT HIGH ENERGY MANOEUVRES WI 5NM RADIUS 525635N 0010726E (MUCKLEBURGH). MAJORITY ACT AT 2000FT AGL AND BLW. ACFT MAY OPR OUTSIDE AREA AND MAY NOT COMPLY WITH RAC. ACFT SHALL REMAIN CLR OF CONTROLLED AIRSPACE. CREWS WISHING TO TRANSIT AREA SHOULD CTC HATCHET CONTROL ON 265.625MHZ, 266.700MHZ OR VHF 149.550MHZ. OPS CTC 07771 833953 OR 07827937701. 14-12-0056/OPS 2. SFC - 24000FT AMSL, 08-11 0800-2300, 12 0800-1500, 08 DEC 08:00 2014 UNTIL 12 DEC 15:00 2014. CREATED: 04 DEC 15:34 2014
