Auteur Topic: FWIT 2014 air to ground  (gelezen 5970 keer)
Offline Superfuse
« Gepost op: 17 juli 2014, 14:32:59 »
http://www.defensie.nl/binaries/defensie/documenten/besluiten/2014/07/15/oefening-fwit-14-tot-en-met-22-augustus/Beschikking+instelling+oefengebieden+FWIT+2014+%28air+to+ground-fase%29.pdf
SPECIAL RULES ZONE 'BVG DELTA' ACTIVATED FOR 'FWIT 2014'
IN AREA:
530917N0044028E - 531106N0043808E ALONG 12NM ARC WITH CENTRE
531500N0045700E CLOCKWISE TO 531500N0043701E - 531500N0044341E ALONG
8NM ARC WITH CENTRE 531500N0045700E CLOCKWISE TO 532229N0045220E -
532624N0051000E - 533000N0053400E - 534000N0063000E -
533338N0063624E - 533122N0064020E - 532254N0063235E -
532226N0063128E - 524803N0051711E - 524707N0050800E -
525645N0050800E - 531100N0045124E BACK TO 530917N0044028E BTN 1200FT
AMSL/FL195.
EHR 2,ALL EHR 4 AREAS ARE EXCLUDED. HELICOPTER ROUTES
KZ02, KZ05 AND KZ06 2NM ON EACH SIDE OF THE ROUTE AND BTN SFC/3000FT
AMSL ARE EXCLUDED.
AREA PROHIBITED FOR NON PARTICIPATING ACFT. PARTICIPATING AND
AUTHORISED CROSSING TFC CONTACT DUTCH MIL ACC PRIOR ENTRY AREA.
WITHIN THE AREA THE USE OF SSR TRANSPONDER MODE A, C OR S IS
MANDATORY. 1200FT AMSL - FL195, AUG 14-15 18-22 0730-1030 1130-1430, 14 AUG
07:30 2014 UNTIL 22 AUG 14:30 2014
. CREATED: 17 JUL 07:57 2014
TEMPORARY SPECIAL RULES ZONES 'DRENTHE', 'DRENTHE NORTH', 'DRENTHE
SOUTH'
AND 'HOOGEVEEN AREA' ACTIVATED FOR 'FWIT 2014'.
AREA 'DRENTHE': 525714N0071102E ALONG THE GERMAN BORDER TO
521948N0070256E - 521811N0064627E - 522808N0062830E -
523821N0062000E - 524546N0062000E - 525228N0063042E BACK TO
525714N0071102E BTN 1200FT AMSL/FL190.
AREA 'DRENTHE NORTH': 525259N0063500E - 525503N0065221E ALONG 8NM
ARC WITH CENTERPOINT 524812N0064534E CLOCKWISE BACK TO
525259N0063500E BTN GND/1200FT AMSL.
AREA 'DRENTHE SOUTH': PSN 523609N0063314E RADIUS 6NM BTN
GND/1200FT AMSL.
AREA 'HOOGEVEEN': 525210N0063013E - 524252N0063308E -
524217N0062000E - 524546N0062000E BACK TO 525210N0063013E BTN 1200FT
AMSL/FL065.
AREA'S PROHIBITED FOR NON PARTICIPATING ACFT. AUTHORISED CROSSING TFC
CONTACT DUTCH MIL ACC PRIOR ENTERING AREAS. WITHIN THE
AREAS THE USE OF SSR TRANSPONDER MODE A, C OR S IS MANDATORY. GND - FL195, AUG
14-15 18-22 0730-1030 1130-1430, 14 AUG 07:30 2014 UNTIL 22 AUG 14:30 2014. CREATED:
17 JUL 08:14 2014
IN AREA:
AMSL/FL195.
AMSL ARE EXCLUDED.
MANDATORY. 1200FT AMSL - FL195, SEP 08-11 15-18 1730-2030, 08 SEP 17:30 2014
UNTIL 18 SEP 20:30 2014
. CREATED: 17 JUL 07:58 2014
SOUTH'
GND/1200FT AMSL.
AMSL/FL065.
AREAS THE USE OF SSR TRANSPONDER MODE A, C OR S IS MANDATORY. GND - FL195, SEP
08-11 15-18 1730-2030, 08 SEP 17:30 2014 UNTIL 18 SEP 20:30 2014. CREATED: 17
JUL 08:15 2014
IN AREA:
AMSL/FL195.
AMSL ARE EXCLUDED.
MANDATORY. 1200FT AMSL - FL195, OCT 06-10 13-16 1300-1630 1730-2030, 06 OCT
13:00 2014 UNTIL 16 OCT 20:30 2014
. CREATED: 17 JUL 08:03 2014
SOUTH'
GND/1200FT AMSL.
AMSL/FL065.
AREAS THE USE OF SSR TRANSPONDER MODE A, C OR S IS MANDATORY. GND - FL195, OCT
06-10 13-16 1300-1630 1730-2030, 06 OCT 13:00 2014 UNTIL 16 OCT 20:30 2014. CREATED:
17 JUL 08:17 2014
Offline Superfuse
Re: FWIT 2014 air to ground
« Reactie #1 Gepost op: 17 juli 2014, 16:10:02 »
Er is meer.
TEMPORARY SPECIAL RULES ZONE 'DE PEEL A' ACTIVATED FOR FWIT 2014.
AREA 'DE PEEL A': PSN 513102N0055120E RADIUS 6.5NM BTN GND/FL245.
AREA 'DE PEEL B': PSN 513112N0060144E - 512000N0060209E -
511510N0055700E - 511520N0054850E - 512158N0053934E ALONG THE BORDER
OF EHDP CTR BACK TO 513112N0060144E BTN 1200FT AMSL/2500FT AMSL.
MANDATORY. GND - FL245, AUG 14-15 18-22 0730-1030 1130-1430, 14 AUG 07:30 2014
. CREATED: 17 JUL 07:26 2014
MANDATORY. GND - FL245, SEP 08-11 15-18 1730-2030, 08 SEP 17:30 2014 UNTIL 18
SEP 20:30 2014
. CREATED: 17 JUL 07:38 2014
MANDATORY. GND - FL245, OCT 06-10 13-16 1300-1630 1730-2030, 06 OCT 13:00 2014
. CREATED: 17 JUL 07:43 2014
Offline Superfuse
« Reactie #2 Gepost op: 23 juli 2014, 17:00:44 »
TEMPORARY SPECIAL RULES ZONE 'MARNEWAARD A' ACTIVATED FOR 'FWIT
2014'.
AREA: 532521N0062846E ALONG 8NM ARC WITH CENTERPOINT 532300N0061600E
CLOCKWISE TO 532308N0062921E - 531517N0061235E ALONG THE 8NM ARC TO
532359N0060244E BACK TO 532521N0062846E BTN GND/1200FT AMSL.
EHR 2 EXCLUDED.
TFCCONTACT DUTCH MIL ACC PRIOR ENTERING AREAS. WITHIN THE
AREAS THE USE OF SSR TRANSPONDER MODE A, C OR S IS MANDATORY. GND - 1200FT AMSL,
AUG 14-15 18-22 0730-1030 1130-1430, 14 AUG 07:30 2014 UNTIL 22 AUG 14:30 2014.
CREATED: 23 JUL 06:53 2014
2014'
EHR 2 EXCLUDED.
SEP 08-11 15-18 1730-2030, 08 SEP 17:30 2014 UNTIL 18 SEP 20:30 2014. CREATED:
23 JUL 06:55 2014
2014'
EHR 2 EXCLUDED.
OCT 06-10 13-16 1300-1630 AND 1730-2030, 06 OCT 13:00 2014 UNTIL 16 OCT 20:30
2014
. CREATED: 23 JUL 06:58 2014
Offline Superfuse
« Reactie #4 Gepost op: 1 oktober 2014, 14:18:11 »
TEMPORARY SPECIAL RULES ZONE 'BRAVO' ACTIVATED FOR 'FWIT 2014'
AREA: 533000N0044600E - 543000N0044600E - 543000N0043209E -
533000N0033844E BACK TO 533000N0044600E BTN FL055/FL660.
AREA PROHIBITED FOR NON PARTICIPATING ACFT. AUTHORISED CROSSING TFC
CONTACT DUTCHMIL ACC PRIOR ENTERING AREA. WITHIN THE AREA THE USE OF
SSR TRANSPONDER MODE A, C OR S IS MANDATORY. FL055 - FL660, OCT 06-10 13-16
1300-1630 1730-2030, 06 OCT 13:00 2014 UNTIL 16 OCT 20:30 2014. CREATED: 01 OCT
12:53 2014
Offline Superfuse
