Auteur Topic: duplexer gezocht:100-170 en 220-400MHz  (gelezen 10929 keer)
Re: duplexer gezocht:100-170 en 220-400MHz
« Reactie #15 Gepost op: 12 september 2013, 21:56:04 »
mmm mil. vhf band zit er net buiten........... ;)
« Reactie #16 Gepost op: 14 september 2013, 14:07:50 »
Zou dit een goede oplossing zijn?(of zijn er goedkopere oplossingen? we blijven hollander he)
het gaat nu alleen om de hk014 antenne die een vhf en 2 uhf scanners moet ''voeden''
graag jullie advies
m.vr.g.r john
STRIDSBERG
MCA204M
VHF/UHF Receiver Multicoupler - 25 MHz to 1 GHz - 4 Ports               NATO / NSN number:  5865-01-532-0314
    VHF/UHF Frequency Range
   25 MHz Input High-Pass Filter
   OP1dB = 17 dBm     OIP3 = 31 dBm
   No Signal Loss to Output Ports
   Rugged Cast Aluminum Case
MCA204M is an active multicoupler designed to distribute VHF/UHF antenna signals to four receivers without loss and with high isolation between ports. It is specifically suited for signal intercept stations, both fixed or mobile platforms. It can be used in any VHF/UHF monitoring post using receivers, scanners or spectrum analyzers. The MCA204M has a mechanical and electrical design construction that will meet any government, military or commercial specification. This unit is designed to give high performance results in any radio monitoring post using multiple intercept receivers. Rugged die-cast aluminum enclosure with a black powder coat finish is standard, olive-drab green (MIl-841OD) is also available on request.
If only two (2) output ports are needed model MCA202M is available. This unit have the same specifications as the MCA204M and in the same case style..
