Auteur Topic: AF1 airborne Baghdad  (gelezen 14203 keer)
Offline Discuscs
Re: AF1 airborne Baghdad
« Reactie #15 Gepost op: 7 april 2009, 22:49:26 »
However, one version of the Gulfstream IV that is rarely seen is the USAF C-20C, which isn't listed in anywhere and is part of a classified programme. Three C-20C aircraft (85-0050 c/n 456, 85-0049 c/n 473 and 86-0403 c/n 473) are based at Andrews AFB in Maryland and are operated by the Presidential Airlift Group (PAG) of the 89th Airlift Wing. The C-20C aircraft are part of a secret programme known as COOP (Continuity Of government Operations Programme) and are used to transport the President and other VVIPs in the event of a national emergency. The three C-20C aircraft are equipped with a comprehensive communication system installed by E-Systems and designed to enable operations in a post-nuclear environment. As part of this rol, whenever the US President or another VVIP travels anywhere in Air Force One, a C-20C is usually positioned discretely at an adjacent airfield, just in case the President or VVIP has to suddenly depart in a hurry and Air Force One has been disabled.
http://www.spyflight.co.uk/IVsp.htm
BC780XLT, Icom R5, Commtel 205, Yaesu FRG100
Offline BlackBox
« Reactie #16 Gepost op: 7 april 2009, 22:57:27 »
Hmmm het duurt me net iets te lang, zouden doorsteken via France?
EDIT 0:05 overhead D üsseldorf!
Good monitoring!
Frequency Monitor Centre
Offline BlackBox
« Reactie #17 Gepost op: 7 april 2009, 23:28:05 »
Je moet nu wat gaan zien Joost!
Good monitoring!
Offline BlackBox
« Reactie #18 Gepost op: 7 april 2009, 23:37:49 »
AF1 checking in Maastricht 132.635 Maastricht Eurocontrol
Good monitoring!
Offline Discuscs
« Reactie #19 Gepost op: 7 april 2009, 23:52:52 »
Door naar Londen 126.780 MHz
Offline BlackBox
« Reactie #20 Gepost op: 8 april 2009, 00:01:08 »
Routing OTBED 53° 17' 17N 0° 1' 55E, en BAGSO 53° 40' 48N 5° 30' 0W
Good monitoring!
Offline BlackBox
« Reactie #21 Gepost op: 8 april 2009, 00:31:28 »
SAM4572 (Sierra 4572) ook gepasseerd via 135.975 > 118.500 > 126.775
Good monitoring!
