Auteur Topic: PDW 3.2b01 Closes/Crashes  (gelezen 2420 keer)
Offline Cwiley
« Gepost op: 12 mei 2020, 14:57:45 »
Running Version 3.2b01 being fed by SDR#.
Computer is Windows 10 box with 8GB of memory, Intel Core i3-8100 CPU 3.6GHZ with 1TB HDD from Fall 2018.
Generally get between 95-100% decoding. For emailing, have to run stunnel.
I have my power settings to never shut down the HD.
Within a 24 hour period, the program will close on it's own.
Anyone else experiencing an unscheduled shut down?
Offline Cwiley
Re: PDW 3.2b01 Closes/Crashes
« Reactie #1 Gepost op: 13 mei 2020, 02:53:06 »
Still not sure what is causing the crashes, but found a program called "Restart on Crash" that monitors for the program closing and will automatically restart it.
  • Rene - Rotterdam
« Reactie #2 Gepost op: 13 mei 2020, 06:15:56 »
Version 3.2b01 supports SSL, so you shouldn't need stunnel.
Did you check if the problem remains with a previous version of PDW?
