Auteur Topic: Nieuwe Firmware Airspy (release date 8/5, Airspy Firmware version v1.0.0-rc10-6)  (gelezen 2159 keer)
Offline gizmo436
Nu te downloaden en te installeren :
Airspy Firmware version v1.0.0-rc10-6 :  https://github.com/airspy/airspyone_firmware/releases/download/v1.0.0-rc10-6/airspy_fw_v1.0.0-rc10-6-g4008185.zip
https://github.com/airspy/airspyone_firmware/releases/tag/v1.0.0-rc10-6
This release improves the overall phase noise, tuning accuracy, dynamic range and spur responses.
What changed:
*More accurate R820T/2 tuning.
*Fast R820T/2 register update by only sending the actual changes. Useful for fast scanning.
*The R820T/2 reference clock is now fed directly from the 25 MHz TCXO. No noise contribution from PLL_A at all when using the internal TCXO.
*The MCU and ADC reference clock is now using PLL_B of Si5351 in Integer mode with power of two dividers.
*EXT_CLK now feeds PLL_A for the R820T/2 and PLL_B for the LPC4370 with optimal Integer Mode and power of two dividers.
*Drive level reduced to 2mA per clock. This significantly reduces the spurs.
Hoe te installeren :
https://github.com/airspy/airspyone_firmware/wiki/Windows-how-to-flash-airspy-firmware
Maurice
Offline gizmo436
Hoe te checken welke FIRMWARE je nu op je AIRSPY hebt :
https://github.com/airspy/airspyone_firmware/wiki/How-to-check-the-firmware-version
was dit vergeten te zeggen in bovenstaande post
gr
Offline gizmo436
Onze vrienden van Tech Minds hebben een keurige uitleg video gemaakt hoe de update te doen:
AIRSPY R2 Software Defined Radio Firmware Update Procedure
https://twitter.com/TechMindsYT/status/1259152618322120704?s=20
met dank aan Tech Minds
groeten
Maurice
