Auteur Topic: FWIT 2019 Air to Ground  (gelezen 2045 keer)
Offline Superfuse
« Gepost op: 9 augustus 2019, 10:15:33 »
TEMPORARY RESTRICTED AREA 'ALPHA' ACTIVATED FOR MIL EXER 'FWIT
2019'
AREA: 530917N 0044028E - 531106N 0043808E ALONG
12NM ARC WITH CENTRE 531500N 0045700E CLOCKWISE TO
531500N 0043701E - 531500N 0044341E ALONG 8NM ARC WITH CENTRE
531500N 0045700E CLOCKWISE TO 532229N 0045220E - 532624N 0051000E -
533000N 0053400E - 534000N 0063000E - 533338N 0063624E - 533122N
0064020E - 532254N 0063235E -524803N 0051711E - 524707N 0050800E -
525645N 0050800E - 531100N 0045124E BACK TO 530917N 0044028E BTN
2000FT AMSL/FL245.
CTR EHLW, EHR4, EHR4A, EHR4B, EHR4C, EHR4D, EHR4E AND EHR2 ARE
EXCLUDED. HELICOPTER MAIN ROUTES KY602, KY605 AND KY606 2NM ON EACH
SIDE OF THE ROUTE UP TO 3000FT AMSL ARE EXCLUDED.
AREA PROHIBITED FOR NON PARTICIPATING ACFT. SAR, POLICE AND
HELICOPTER EMERGENCY MEDICAL SERVICES EXEMPTED AFTER PRIOR
PERMISSION FROM MILATCC SCHIPHOL.
PARTICIPATING ACFT CONTACT MILATCC SCHIPHOL OR CONTROL AND REPORTING
CENTRE 'BANDBOX FA' PRIOR ENTERING AREA. FOR PARTICIPATING ACFT THE
USE OF SSR TRANSPONDER MODE S OR 3A AND C IS MANDATORY. 2000FT AMSL - FL245,EVERY MON-FRI 0800-1000 1200-1400, 26 AUG 08:00 2019 UNTIL 06 SEP 14:00 2019.CREATED: 08 AUG 05:22 2019
TEMPORARY RESTRICTED AREA 'DRENTHE' ACTIVATED FOR MIL EXER 'FWIT
2019'.
AREA: 525715N 0071115E ALONG DUTCH/GERMAN BORDER TO 521959N 0070318E
- 521811N 0064627E - 522808N 0062830E - 523326N 0062406E - 524505N
0062407E - 525242N 0063222E BACK TO 525715N 0071115E BTN 2000FT
AMSL/FL195.
THE FOLLOWING AREAS ARE EXCLUDED:
AREA AROUND HOOGEVEEN 525103N 0063034E - 524505N 0062407E - 524228N
0062407E - 524252N 0063308E BACK TO 525103N 0063034E BTN 2000FT
AMSL/FL065.
AREA AROUND TWENTE 521827N 0064856E - 522138N 0065918E - 521948N
0070127E BACK TO 521827N 0064856E BTN 2000FT AMSL/2200FT AMSL.
SAR, POLICE AND HELICOPTER EMERGENCY MEDICAL SERVICES EXEMPTED AFTER
PRIOR PERMISSION FROM MILATCC SCHIPHOL. PARTICIPATING ACFT CONTACT
MILATCC SCHIPHOL OR CONTROL AND REPORTING CENTRE 'BANDBOX FA' PRIOR
ENTERING AREA. FOR PARTICIPATING ACFT THE USE OF SSR TRANSPONDER
MODE S OR 3A AND C IS MANDATORY. 2000FT AMSL - FL195, EVERY MON-FRI 0800-1000 1200-1400, 26 AUG 08:00 2019 UNTIL 06 SEP 14:00 2019. CREATED: 09 AUG 08:08 2019
TEMPORARY RESTRICTED AREA 'DRENTHE 2' ACTIVATED FOR MIL EXER
'FWIT 2019'
- 521909N 0065524E - 523714N 0062406E - 524505N 0062407E - 525242N
0063222E BACK TO 525715N 0071115E BTN FL195/FL245.
USE OF SSR TRANSPONDER MODE S OR 3A AND C IS MANDATORY. FL195 - FL245, EVERY MON-FRI 0800-1000 1200-1400, 26 AUG 08:00 2019 UNTIL 06 SEP 14:00 2019. CREATED:07 AUG 12:34 2019
Offline Superfuse
Offline DionL
Re: FWIT 2019 Air to Ground
« Reactie #2 Gepost op: 29 augustus 2019, 09:06:52 »
Zijn er ook frequenties bekend?
ubc125xlt+Magnum Scan Stick 2000 en Diamond RH795
