Auteur Topic: FWIT 2017  (gelezen 4944 keer)
Offline Superfuse
Re: FWIT 2017
« Reactie #1 Gepost op: 3 augustus 2017, 07:47:24 »
TEMPORARY RESTRICTED AREA 'DRENTHE SOUTH' ACTIVATED FOR MIL EXER
'FWIT 2017' IN AREA: PSN 523609N0063314E RADIUS 6NM BTN GND/1200FT
AMSL.
AREA PROHIBITED FOR NON PARTICIPATING ACFT. PARTICIPATING ACFT
CONTACT DUTCHMIL ACC OR CONTROL AND REPORTING CENTRE 'BANDBOX FA'
PRIOR ENTERING AREA.
PARTICIPATING ACFT THE USE OF SSR TRANSPONDER MODE S OR 3A AND C IS
MANDATORY. GND - 1200FT AMSL, DAILY 0730-1030 1130-1430, 09 AUG 07:30 2017 UNTIL
11 AUG 14:30 2017
. CREATED: 02 AUG 13:46 2017
TEMPORARY RESTRICTED AREA 'DRENTHE NORTH' ACTIVATED FOR MIL EXER
'FWIT 2017' IN AREA: 525259N0063504E - 525501N0065221N ALONG 8NM ARC
WITH CENTRE 524812N0064534E CLOCKWISE BACK TO 525259N0063504E BTN
GND/1200FT AMSL.
11 AUG 14:30 2017
. CREATED: 02 AUG 13:29 2017
TEMPORARY RESTRICTED AREA 'DRENTHE' ACTIVATED FOR MIL EXER 'FWIT
2017'
IN AREA: 525715N0071107E ALONG THE DUTCH/GERMAN BORDER TO
521958N0070303E - 521811N0064627E - 522808N0062830E -
523821N0062000E - 524546N0062000E - 525228N0063042E BACK TO
525715N0071107E BTN 1200FT AMSL/FL190.
MANDATORY. 1200FT AMSL - FL190, DAILY 0730-1030 1130-1430, 09 AUG 07:30 2017
UNTIL 11 AUG 14:30 2017
. CREATED: 02 AUG 13:06 2017
AMSL.
MANDATORY. GND - 1200FT AMSL, MON-FRI 0730-1030 1130-1430, 21 AUG 07:30 2017
UNTIL 01 SEP 14:30 2017
. CREATED: 02 AUG 13:48 2017
GND/1200FT AMSL.
. CREATED: 02 AUG 13:31 2017
2017'
MANDATORY. 1200FT AMSL - FL190, MON-FRI 0730-1030 1130-1430, 21 AUG 07:30 2017
. CREATED: 02 AUG 13:11 2017
Offline Belenos
Re: FWIT 2017
« Reactie #3 Gepost op: 3 augustus 2017, 11:08:42 »
FWIT gaat ook de grens over zo te lezen, en er wordt avond/nachtgevlogen:
B0753/17 - TEMPORARY RESTRICTED AREA ED-R PARCHIM ESTABLISHED FOR MILITARY EXERCISE FWIC: 541423N0113732E 540752N0121320E 531906N0114812E 532325N0112854E 533440N0111732E 541423N0113732E. FLIGHTS WITHIN THE RESTRICTED AREA ED-R PARCHIM BY AIRCRAFT NOT PARTICIPATING IN THE EXERCISE FWIC ARE ONLY POSSIBLE AFTER PRIOR PERMISSION FROM THE COMPETENT ATC UNIT. CLEARANCE TO CROSS THE RESTRICTED AREA CAN ONLY BE ISSUED IF THERE IS NO MILITARY AIR TRAFFIC IN THE RESTRICTED AREA. THE COMPETENT AIR TRAFFIC CONTROL UNIT WILL MAINTAIN ADEQUATE DISTANCES FROM THIS AREA FOR IFR TRAFFIC. FL160 - FL220, 08 0800-1030, 09 10 DAILY 0700-1000, 14-17 DAILY 2000-2300, 21-25 DAILY 0700-0900, 08 AUG 08:00 2017 UNTIL 25 AUG 09:00 2017. CREATED: 02 AUG 06:19 2017
Offline Superfuse
Re: FWIT 2017
« Reactie #5 Gepost op: 3 augustus 2017, 11:16:14 »
FWIT wordt genoemd in dit bericht
Offline Lord Flashheart
  • Boardmoderator
    • 24 December 1944
Re: FWIT 2017
« Reactie #6 Gepost op: 3 augustus 2017, 11:25:41 »
Volkel gaat knokken in de TMA- Delta,  FWIT komt de week erop. en de weken daar weer op is Volkel weer heer en meester in de TMA-D. zo lees ik het.
Offline Superfuse
Re: FWIT 2017
« Reactie #7 Gepost op: 3 augustus 2017, 11:50:43 »
Al met al genoeg om naar te luisteren ;)
Offline Belenos
Re: FWIT 2017
« Reactie #8 Gepost op: 3 augustus 2017, 20:37:38 »
Thanks voor de opheldering! Jep genoeg te doen komende tijd  :)
Offline Superfuse
Re: FWIT 2017
« Reactie #9 Gepost op: 6 augustus 2017, 07:31:19 »
TEMPORARY RESTRICTED AREA 'ALPHA' ACTIVATED FOR MIL EXER 'FWIT 2017'
IN AREA: 530917N0044028E - 531106N0043808E ALONG 12NM ARC WITH
CENTRE 531500N0045700E CLOCKWISE TO 531500N0043701E -
531500N0044341E ALONG 8NM ARC WITH CENTRE 531500N0045700E CLOCKWISE
TO 532229N0045220E - 532624N0051000E - 533000N0053400E -
534000N0063000E - 533338N0063624E - 533122N0064020E -
532254N0063235E - 524803N0051711E - 524707N0050800E -
525645N0050800E - 531100N0045124E BACK TO 530917N0044028E BTN 1200FT
AMSL/FL195.
EHR4, EHR4A, EHR4B, EHR4C, EHR4D, EHR4E AND EHR2 ARE EXCLUDED.
HELICOPTER ROUTES KY602, KY605 AND KY606 2NM ON EACH SIDE OF THE
ROUTE BTN 1500FT AMSL/3000FT AMSL ARE EXCLUDED.
MANDATORY. 1200FT AMSL - FL195, DAILY 0730-1030 1130-1430, 09 AUG 07:30 2017
. CREATED: 04 AUG 10:50 2017
AMSL/FL195.
MANDATORY. 1200FT AMSL - FL195, MON-FRI 0730-1030 1130-1430, 21 AUG 07:30 2017
. CREATED: 04 AUG 10:52 2017
Offline Nightwish
  • Systeembeheerder
Re: FWIT 2017
« Reactie #10 Gepost op: 9 augustus 2017, 18:10:26 »
Heeft iemand voor mij misschien een lijstje met frequenties die gebruikt worden? ik woon middenin drenthe maar heb zelf geen mogelijkheid te searchen (zit niet fysiek bij de scanner onder werktijd)
would be greatly appriciated :)
  • Boardmoderator
    • 24 December 1944
Re: FWIT 2017
« Reactie #11 Gepost op: 9 augustus 2017, 18:30:14 »
Grote kans dat de monitor freq een VHF van Rapcon wordt, maar tegenwoordig zijn ook een groot aantal F-16 dual UHF capable.
FAC wise zal het "even" zoeken worden en ik schat in dat dat nog geen minuut duurt voordat die gevonden zijn.
Echter je geeft aan dat je niet fysiek bij de scanner kan. Mijn inschatting is dat er een aantal freqs zullen zijn die gedurende FWIT niet zullen veranderen.
Met andere woorden, hou de chat in de gaten, of dit (deze??) topic en dan lijkt het me niet geheel onmogelijk dat hier op den duur de freqs voorbij zullen komen.
De standaard freqs 340.550 358.350 en 360.950 worden gebruikt voor de FAC opleiding en zullen daarom denk ik nu niet gebruikt gaan worden.
Maar niks is zo veranderlijk als de luchtvaart dus je zou kunnen overwegen om deze er voor de zekerheid in te kloppen.
Offline Nightwish
  • Systeembeheerder
Re: FWIT 2017
« Reactie #12 Gepost op: 9 augustus 2017, 19:46:57 »
ah, ik zal het eens in de gaten houden.
Scenario is dat ik een scanner aan mijn buitenantenne thuis heb, deze blaast zijn output via een server naar een eigen site waar ik die vervolgens kan uitluisteren. scanner controls gaan meestal icm teamviewer en freescan. en ik kan natuurlijk niet in de baas zijn tijd met de scanner gaan klieren :p het luisteren is echter geen probleem :)
