Auteur Topic: Mobitex - Zenderlokaties & Base-ID's  (gelezen 77083 keer)
Online Hunter
« Gepost op: 1 juni 2008, 12:13:29 »
Frequentie BaseID Lokatie
424,0875 MHz 0137 Hilversum
424,0875 MHz 0201 Alkmaar
424,0875 MHz 0413 Den-Haag (CS)
424,1125 MHz 010C Woerden
424,1125 MHz 0137 Hilversum
424,1125 MHz 0202 Almere-Stad
424,1125 MHz 0318 Rotterdam-West
424,1125 MHz 070A Venray
424,1125 MHz 0A16 Drachten
424,1375 MHz 0136 Nieuwegein
424,1375 MHz 0309 Hoogvliet
424,1375 MHz 0403 Leiden
424,1375 MHz 0633 Maastricht
424,1375 MHz 0709 Helmond
424,1750 MHz ???? Groningen ???
424,1750 MHz 0115 Maarssen (RAM)
424,1750 MHz 0303 Delft
424,2500 MHz 021A Alphen a/d Rijn
424,2500 MHz 0806 Veenendaal
424,2500 MHz ???? Zaltbommel ???
424,3125 MHz 0413 Den-Haag (CS)
424,3250 MHz 010A Utrecht-Centrum
424,3250 MHz 0207 Amsterdam-Zuid
424,3250 MHz 0336 Zoetermeer
424,3250 MHz 070E Roermond
424,3250 MHz ???? Emmeloord ???
424,3375 MHz 0202 Almere-Stad
424,3375 MHz 0211 Schiphol
424,3375 MHz 0319 Rotterdam-Noord
424,3625 MHz 0136 Nieuwegein
424,3625 MHz 0334 Vlaardingen
424,3625 MHz 0403 Leiden
424,3625 MHz 0633 Maastricht
424,3625 MHz 0A0F Heerenveen
424,4000 MHz ???? Groningen ???
424,4000 MHz 0115 Maarssen (RAM)
424,4000 MHz 0303 Delft
424,4250 MHz 0205 Amsterdam-Sloterdijk
424,4250 MHz 0306 Gouda
424,4250 MHz 0A10 Leeuwarden
424,4250 MHz 0133 Amersfoort
424,4750 MHz 0314 Rotterdam-Oost
424,4750 MHz ???? Harderwijk ???
424,4750 MHz 0711 Weert
424,5375 MHz 011D Bussum
424,5375 MHz 020E Nieuw Vennep
424,5375 MHz 0416 Den-Haag (Scheveningen-Haven)
424,5375 MHz 030D Rotterdam-Centrum
424,5500 MHz 0208 Amsterdam Zuidoost
424,5500 MHz 0310 Den-Haag Zuidwest
424,5625 MHz ???? Bolsward
424,5625 MHz 010A Utrecht-Centrum
424,5625 MHz 0233 Amsterdam-Noord
424,5625 MHz 0415 Leidschendam
424,5875 MHz 020A Haarlem
424,6250 MHz 021A Alphen a/d Rijn
424,6250 MHz 0806 Veenendaal
424,6250 MHz 0307 Europoort (EBS)
424,6500 MHz 0205 Amsterdam-Sloterdijk
424,6500 MHz 0306 Gouda
424,6500 MHz 0133 Amersfoort
424,6500 MHz 0317 Rotterdam-Feijenoord
424,7000 MHz 0333 Rotterdam-IJsselmonde
424,7000 MHz ???? Assen ???
424,7000 MHz 0134 Doorn
424,7000 MHz 0A1B Sneek
424,7625 MHz 0102 Utrecht-Uithof
424,7625 MHz 0212 Sassenheim
424,7625 MHz 030D Rotterdam Centrum
424,7750 MHz 0208 Amsterdam Zuidoost
424,7750 MHz 0310 Den-Haag Zuidwest
424,7750 MHz 070B Venlo
Offline Jeff2879203
Re: Mobitex - Zenderlokaties & Base-ID's
« Reactie #1 Gepost op: 1 juni 2008, 12:39:15 »
Hartstikke bedankt <3 voor de frequenties + plaatsnamen.
UBC 3300XLT | UBC 69XLT | UBC 780XLT | Commtel-13 |  Puxing PX777
Offline Stefan uit 8terberg
« Reactie #2 Gepost op: 2 juni 2008, 13:08:20 »
aanvullings
424.325   041A   ??
424.475   001C   ??
424.5625  041A   ??
424.700    001A   Doorn
424.3375   0308  ??
424.175    200C   ??
424.400    0402   ??
424.200    0410  ??
dit is wat ik zie vanuit 8terberg
stefan
No Farmers , No Food
  • Zendamateur
  • PC5E
    • http://www.pc5e.nl
« Reactie #3 Gepost op: 2 juni 2008, 14:19:54 »
Hoe zie je die base ID's? /me kan ook wel een paar oplepelen dan. ;)
PC5E / Robert Elsinga =8- )
Uniden UBC3500XLT, Whistler TRX-1, Icom IC7000, Retevis RT82+RT90, Polmar DB-50M, Hytera PD785G, TYT MD380.
Frequentielijsten Nederland.
« Reactie #4 Gepost op: 2 juni 2008, 14:34:08 »
Citaat van: "elsinga"
met behulp van die eerder genoemde ID's (Base-ID's) zal het in de toekomst mogelijk zijn om een file te maken met daarin zenderlokaties gekoppeld aan deze Base-ID's waardoor PDW in de titelbalk de lokatie van de huidige zender weer kan geven.
test versie PDW
stefan
Offline kevin27
  • Manschap A VRU
« Reactie #5 Gepost op: 2 juni 2008, 14:41:20 »
Citaat van: "Stefan uit 8terberg"
test versie PDW
stefan
Hoe kom je aan die Test versie ?
Alle berichtgeving is op persoonlijke titel
  • Rene - Rotterdam
« Reactie #6 Gepost op: 2 juni 2008, 14:44:39 »
De vangst in Rotterdam-Oost: 14 stuks, waarvan een onbekende:
424.0875  - Base ID 0102
Online Hunter
« Reactie #7 Gepost op: 2 juni 2008, 15:19:43 »
Citaat van: "kevin27"
Die komt bij mij vandaan, echter zitten er nog teveel fouten en onzekerheden in waardoor ik deze niet te ver wil verspreiden. Stefan is een van mijn vaste testers, tot bepaalde problemen zijn opgelost wil ik hem niet te ver verspreiden.
  • Zendamateur
  • PC5E
« Reactie #8 Gepost op: 2 juni 2008, 15:53:25 »
Okidoki. Moet je nog even wachten tot je de Base ID's uit deze regio krijgt. ;)
Offline Jeff2879203
« Reactie #9 Gepost op: 2 juni 2008, 17:51:49 »
Zender 424.1375 zit tot nu toe alleen nog maar een taxi bedrijf, ik probeer nog even op te zoeken welk bedrijf (of iemand kan het mij vertellen). want ik heb al meer dan 50 berichten ervan ontvangen...
Die zelfde taxi gebruikt ook 424.5625 (zelfde berichten formats).
424.3250 word ook door 'tzelfde taxi bedrijf gebruikt waarschijnlijk maar ook door ambulances van Antonius ziekenhuis..
Heeft iemand mobitex logboeks, zou ik ze graag ontvangen op mijn email. Ik wil eens patronen in berichten gaan zoeken en ook eens vergelijken met mijn logsboeken. Heb mobitex al 48 uur aan nu 2 frequenties aan het testen.
mvg,
Jeffrey
« Reactie #10 Gepost op: 3 juni 2008, 23:16:02 »
Even een dienstmededeling (zoals Johan ook al had aangegeven in het andere topic):
Strooi niet met privégegevens en zie je leuke dingen die niet voor jou bestemd zijn, hou dit dan voor jezelf. Vaak weten deze gebruikers zelf niet dat de berichten zijn mee te lezen. Voor je het doorhebt krijg je een sneeuwbaleffect en komen dit soort berichten online met mogelijke gevolgen van dien:
- Gebruikers die stoppen met mobitex en overstappen op GPRS.
- Berichten die niet meer als platte tekst worden weergeven.
- Berichten waar alle interessante dingen worden weggelaten, maar wel met het verzoek om te bellen om deze gegevens.
Dus nogmaals:
Hou het voor jezelf, ander graaf je spreekwoordelijk je eigen graf en verpest je het ook voor anderen die al jaren meelezen.
Offline Mars
« Reactie #11 Gepost op: 3 juni 2008, 23:16:58 »
424.0875 Alkmaar (maar zie geen enkel bericht langskomen op pdw  :( )
vr.gr.
Mars
  • Zendamateur
  • PC5E
« Reactie #12 Gepost op: 16 juni 2008, 19:20:07 »
Ik heb inmiddels deze gespot, vanuit Sintjohannesga, met een porto op de begane grond (oftewel: niet de beste ontvangstcondities):
424.11250   Drachten      BaseID: 050B
424.36250   Heerenveen   BaseID: 2507
424.42500   Leeuwarden   BaseID: 0508
424.56250   Onbekend      BaseID: 2510
424.70000   Onbekend      BaseID: 250D
De twee onbekenden zouden Sneek en Emmeloord kunnen zijn. Maar ook in Ens (vlakbij de brug over de randmeren in de N50) zou volgens de dekkingskaart een zender moeten staan. Ik ben die dekkingskaart overigens kwijt... stond volgens mij op de RAM site, maar kan 'm niet meer vinden... :(
Online Hunter
« Reactie #13 Gepost op: 16 juni 2008, 19:40:48 »
Ik wou net zeggen, ik ben al een kwartier aan het zoeken sinds jouw posting, toen las ik ineens de aanvulling :(
  • Zendamateur
  • PC5E
« Reactie #14 Gepost op: 16 juni 2008, 20:38:08 »
Volgens PDW en de Mobitex control messages zouden er ook nog drie zenders op 424.250, 424.325 en 424.625 moeten zitten, als neighbour channels. Die krijg ik hier overigens niet binnen (maar ja, porto en op de begane grond, wat wil je ook...).
Zal eens zien of ik de boel op de laptop aan de gang krijg, kan ik even boven gaan zitten. ;)
Done inmiddels.
Ik heb nu:
424.25000   onbekend   BaseID: 2409
424.32500   onbekend   BaseID: 040f
424.56250   onbekend      BaseID: 2510
424.70000   onbekend      BaseID: 250D
424.625 krijg ik zelfs op zolder niet mee.
