Scannersoftware => PDW => Topic gestart door: Hunter op 1 juni 2008, 12:13:29
Titel: Mobitex - Zenderlokaties & Base-ID's
Bericht door: Hunter op 1 juni 2008, 12:13:29
Frequentie BaseID Lokatie
424,0875 MHz 0137 Hilversum
424,0875 MHz 0201 Alkmaar
424,0875 MHz 0413 Den-Haag (CS)
424,1125 MHz 010C Woerden
424,1125 MHz 0137 Hilversum
424,1125 MHz 0202 Almere-Stad
424,1125 MHz 0318 Rotterdam-West
424,1125 MHz 070A Venray
424,1125 MHz 0A16 Drachten
424,1375 MHz 0136 Nieuwegein
424,1375 MHz 0309 Hoogvliet
424,1375 MHz 0403 Leiden
424,1375 MHz 0633 Maastricht
424,1375 MHz 0709 Helmond
424,1750 MHz ???? Groningen ???
424,1750 MHz 0115 Maarssen (RAM)
424,1750 MHz 0303 Delft
424,2500 MHz 021A Alphen a/d Rijn
424,2500 MHz 0806 Veenendaal
424,2500 MHz ???? Zaltbommel ???
424,3125 MHz 0413 Den-Haag (CS)
424,3250 MHz 010A Utrecht-Centrum
424,3250 MHz 0207 Amsterdam-Zuid
424,3250 MHz 0336 Zoetermeer
424,3250 MHz 070E Roermond
424,3250 MHz ???? Emmeloord ???
424,3375 MHz 0202 Almere-Stad
424,3375 MHz 0211 Schiphol
424,3375 MHz 0319 Rotterdam-Noord
424,3625 MHz 0136 Nieuwegein
424,3625 MHz 0334 Vlaardingen
424,3625 MHz 0403 Leiden
424,3625 MHz 0633 Maastricht
424,3625 MHz 0A0F Heerenveen
424,4000 MHz ???? Groningen ???
424,4000 MHz 0115 Maarssen (RAM)
424,4000 MHz 0303 Delft
424,4250 MHz 0205 Amsterdam-Sloterdijk
424,4250 MHz 0306 Gouda
424,4250 MHz 0A10 Leeuwarden
424,4250 MHz 0133 Amersfoort
424,4750 MHz 0314 Rotterdam-Oost
424,4750 MHz ???? Harderwijk ???
424,4750 MHz 0711 Weert
424,5375 MHz 011D Bussum
424,5375 MHz 020E Nieuw Vennep
424,5375 MHz 0416 Den-Haag (Scheveningen-Haven)
424,5375 MHz 030D Rotterdam-Centrum
424,5500 MHz 0208 Amsterdam Zuidoost
424,5500 MHz 0310 Den-Haag Zuidwest
424,5625 MHz ???? Bolsward
424,5625 MHz 010A Utrecht-Centrum
424,5625 MHz 0233 Amsterdam-Noord
424,5625 MHz 0415 Leidschendam
424,5875 MHz 020A Haarlem
424,6250 MHz 021A Alphen a/d Rijn
424,6250 MHz 0806 Veenendaal
424,6250 MHz 0307 Europoort (EBS)
424,6500 MHz 0205 Amsterdam-Sloterdijk
424,6500 MHz 0306 Gouda
424,6500 MHz 0133 Amersfoort
424,6500 MHz 0317 Rotterdam-Feijenoord
424,7000 MHz 0333 Rotterdam-IJsselmonde
424,7000 MHz ???? Assen ???
424,7000 MHz 0134 Doorn
424,7000 MHz 0A1B Sneek
424,7625 MHz 0102 Utrecht-Uithof
424,7625 MHz 0212 Sassenheim
424,7625 MHz 030D Rotterdam Centrum
424,7750 MHz 0208 Amsterdam Zuidoost
424,7750 MHz 0310 Den-Haag Zuidwest
424,7750 MHz 070B Venlo
Titel: Re: Mobitex - Zenderlokaties & Base-ID's
Bericht door: Jeff2879203 op 1 juni 2008, 12:39:15
Hartstikke bedankt <3 voor de frequenties + plaatsnamen.
Bericht door: Stefan uit 8terberg op 2 juni 2008, 13:08:20
aanvullings
424.325   041A   ??
424.475   001C   ??
424.5625  041A   ??
424.700    001A   Doorn
424.3375   0308  ??
424.175    200C   ??
424.400    0402   ??
424.200    0410  ??
dit is wat ik zie vanuit 8terberg
stefan
Bericht door: elsinga op 2 juni 2008, 14:19:54
Hoe zie je die base ID's? /me kan ook wel een paar oplepelen dan. ;)
Bericht door: Stefan uit 8terberg op 2 juni 2008, 14:34:08
Citaat van: "elsinga"
met behulp van die eerder genoemde ID's (Base-ID's) zal het in de toekomst mogelijk zijn om een file te maken met daarin zenderlokaties gekoppeld aan deze Base-ID's waardoor PDW in de titelbalk de lokatie van de huidige zender weer kan geven.
test versie PDW
stefan
Bericht door: kevin27 op 2 juni 2008, 14:41:20
Citaat van: "Stefan uit 8terberg"
test versie PDW
stefan
Hoe kom je aan die Test versie ?
Bericht door: Discriminator op 2 juni 2008, 14:44:39
De vangst in Rotterdam-Oost: 14 stuks, waarvan een onbekende:
424.0875  - Base ID 0102
Bericht door: Hunter op 2 juni 2008, 15:19:43
Citaat van: "kevin27"
Die komt bij mij vandaan, echter zitten er nog teveel fouten en onzekerheden in waardoor ik deze niet te ver wil verspreiden. Stefan is een van mijn vaste testers, tot bepaalde problemen zijn opgelost wil ik hem niet te ver verspreiden.
Bericht door: elsinga op 2 juni 2008, 15:53:25
Okidoki. Moet je nog even wachten tot je de Base ID's uit deze regio krijgt. ;)
Bericht door: Jeff2879203 op 2 juni 2008, 17:51:49
Zender 424.1375 zit tot nu toe alleen nog maar een taxi bedrijf, ik probeer nog even op te zoeken welk bedrijf (of iemand kan het mij vertellen). want ik heb al meer dan 50 berichten ervan ontvangen...
Die zelfde taxi gebruikt ook 424.5625 (zelfde berichten formats).
424.3250 word ook door 'tzelfde taxi bedrijf gebruikt waarschijnlijk maar ook door ambulances van Antonius ziekenhuis..
Heeft iemand mobitex logboeks, zou ik ze graag ontvangen op mijn email. Ik wil eens patronen in berichten gaan zoeken en ook eens vergelijken met mijn logsboeken. Heb mobitex al 48 uur aan nu 2 frequenties aan het testen.
mvg,
Jeffrey
Bericht door: Remon op 3 juni 2008, 23:16:02
Even een dienstmededeling (zoals Johan ook al had aangegeven in het andere topic):
Strooi niet met privgegevens en zie je leuke dingen die niet voor jou bestemd zijn, hou dit dan voor jezelf. Vaak weten deze gebruikers zelf niet dat de berichten zijn mee te lezen. Voor je het doorhebt krijg je een sneeuwbaleffect en komen dit soort berichten online met mogelijke gevolgen van dien:
- Gebruikers die stoppen met mobitex en overstappen op GPRS.
- Berichten die niet meer als platte tekst worden weergeven.
- Berichten waar alle interessante dingen worden weggelaten, maar wel met het verzoek om te bellen om deze gegevens.
Dus nogmaals:
Hou het voor jezelf, ander graaf je spreekwoordelijk je eigen graf en verpest je het ook voor anderen die al jaren meelezen.
Bericht door: Mars op 3 juni 2008, 23:16:58
424.0875 Alkmaar (maar zie geen enkel bericht langskomen op pdw  :( )
vr.gr.
Mars
Bericht door: elsinga op 16 juni 2008, 19:20:07
Ik heb inmiddels deze gespot, vanuit Sintjohannesga, met een porto op de begane grond (oftewel: niet de beste ontvangstcondities):
424.11250   Drachten      BaseID: 050B
424.36250   Heerenveen   BaseID: 2507
424.42500   Leeuwarden   BaseID: 0508
424.56250   Onbekend      BaseID: 2510
424.70000   Onbekend      BaseID: 250D
De twee onbekenden zouden Sneek en Emmeloord kunnen zijn. Maar ook in Ens (vlakbij de brug over de randmeren in de N50) zou volgens de dekkingskaart een zender moeten staan. Ik ben die dekkingskaart overigens kwijt... stond volgens mij op de RAM site, maar kan 'm niet meer vinden... :(
Bericht door: Hunter op 16 juni 2008, 19:40:48
Ik wou net zeggen, ik ben al een kwartier aan het zoeken sinds jouw posting, toen las ik ineens de aanvulling :(
Bericht door: elsinga op 16 juni 2008, 20:38:08
Volgens PDW en de Mobitex control messages zouden er ook nog drie zenders op 424.250, 424.325 en 424.625 moeten zitten, als neighbour channels. Die krijg ik hier overigens niet binnen (maar ja, porto en op de begane grond, wat wil je ook...).
Zal eens zien of ik de boel op de laptop aan de gang krijg, kan ik even boven gaan zitten. ;)
Done inmiddels.
Ik heb nu:
424.25000   onbekend   BaseID: 2409
424.32500   onbekend   BaseID: 040f
424.56250   onbekend      BaseID: 2510
424.70000   onbekend      BaseID: 250D
424.625 krijg ik zelfs op zolder niet mee.
Bericht door: elsinga op 16 juni 2008, 20:41:59
Citaat van: "hunter"
En ik weet zeker dat ik 'm heb gezien. Was volgens mij in PDF formaat, ik herinner me nog ingezoomd te hebben. Zal in een folder hebben gestaan, gok ik nu. Maar de huidige folder is zonder dekkingskaart. :(
Bericht door: elsinga op 17 juni 2008, 10:39:12
Zou het niet mogelijk zijn om aan de hand van de Neighbour frequencies een soort kaart te maken? Je pakt een base, die geeft die info door, daarna pak je de buurbasissen en herhaalt het kunstje. Zo weet je welke basissen naar welke anderen doorverwijzen. Kun je dan een grid-tekening van maken.
Voorbeeld: zender Heerenveen (id 2507) op frequentie 424.3625 geeft als buurzenders aan:
424.62500 onbekend BaseID: onbekend
Van hieruit pak je dan bijvoorbeeld Leeuwarden en zoekt daar de buurzenders van op. Gokje: daar staan Heerenveen en Drachten ook in ;), waarschijnlijk ook nog een paar (Sneek bijvoorbeeld, die we nog niet expliciet hebben geindentificeerd), maar ook nieuwe zenders (Dokkum?). Als je dat geintje nu herhaalt voor Drachten krijg je weer wat overlap en wat nieuws. En zo bouw je lekker verder aan de kaart.
Voordeel: vanuit 1 zender kom je altijd zijn buren te weten. En door de overlap worden de lokaties van andere zenders veel sneller duidelijk. En de nieuwe zenders die je ontdekt geven daarna ook weer info. :)
Bericht door: elsinga op 17 juni 2008, 17:34:49
Even de buurzenders van Drachten (050B):
424.1375
424.1750
424.2500 (komt ook bij Heerenveen voor)
424.3625 (Heerenveen, wat een verassing)
424.4250 (Leeuwarden, ook geen verassing)
424.5625 (komt ook bij Heerenveen voor)
424.6250 (komt ook bij Heerenveen voor)
424.7000 (komt ook bij Heerenveen voor)
Hieruit concludeer ik dat 424.13750 en 424.1750 ten (noord)oosten van Drachten moeten liggen. Elke andere richting zou ze ook in de lijst van Heerenveen plaatsen. ;)
Bericht door: Hunter op 17 juni 2008, 17:42:32
Ik weet niet of je daar 100% vanuit kunt gaan, ik heb gemerkt dat kanalen soms erg kort op elkaar (her)gebruikt worden. Ook is er een verschil in reikwijdte en antennes. Sommige sites hebben een klein antennetje (0dB Kathrein) en die dekken maar een klein gebied waardoor dat kanaal op kortere afstand dan gebruikelijk weer hergebruikt kan worden. Daarom kan dat kanaal C weliswaar zowel bij zender A als B in de buurlijst staan, terwijl het best weleens 2 totaal verschillende zenders kunnen zijn die toevallig hetzelfde kanaal gebruiken. Vlaardingen en Leiden zitten bijvoorbeeld op hetzelfde kanaal, kijk maar eens op de kaart, zo groot is die afstand niet.
Overigens zitten we nu op een niveau waarover er nog maar weinig mee kunnen praten...
Bericht door: elsinga op 17 juni 2008, 18:15:02
Peter, je hebt uiteraard gelijk. Maar je mag toch hopen, of niet. ;) Aan de andere kant zou het me wel heel erg verbazen als die twee zenders vanuit Drachten gezien westelijk staan...
Ik zal de boel wel even in de gaten houden als ik weer eens onderweg ben. Zo ga ik donderdag de A32 afzakken en kan best eens zien of er ook een zender Meppel is bijvoorbeeld. En in Zwolle. Komende dinsdag kom ik weer langs Noordwolde (richting Veenhuizen), ook een kanshebber voor een zender (al is dat wel wat dicht op Drachten in principe). En vanuit Veenhuizen kan ik wel even kijken of er ook wat te luisteren valt.
Bericht door: Hunter op 17 juni 2008, 19:15:52
Laptopje mee?  ;)
Bericht door: elsinga op 18 juni 2008, 07:04:08
Laptopje mee?  ;)
In de auto niet aan in elk geval. ;) Vanuit Veenhuizen kan ik wel wat ID's scoren, staat de zakelijk fleptop toch al aan (mental note: kabeltjes meenemen).
Bericht door: elsinga op 19 juni 2008, 19:11:07
Ik had vanochtend in de auto 424.250 keihard rond Meppel. Echt als in zonder antenne nog haast ontvangst. :)
Bericht door: elsinga op 20 juni 2008, 15:00:58
En zender met ID 250D (424.7000) heeft als neighbour cells:
424.1125 Drachten
424.3250
424.3625 Heerenveen
424.4250 Leeuwarden
424.5625
Je zou dus zeggen dat deze zender in elk geval ergens in (de buurt van) de driehoek Leeuwarden/Drachten/Heerenveen zoou moeten liggen. Grou of Terhorne of zo. Tenzij de frequenties van Drachten/Leeuwarden/Heerenveen al weer hergebruikt worden...
Bericht door: elsinga op 24 juni 2008, 06:40:56
Ik hoor vanuit Veenhuizen maar 3 zenders:
424.1750 ID=0707
424.4000 ID=0707
424.7000 ID=2707
Omdat de eerste 2 zenders hetzelfde ID hebben zou dat dus 1 cel moeten zijn. En dan gok ik op Assen. Of kan het niet, dat 2 zenders hetzelfde ID hebben?
Bericht door: Hunter op 24 juni 2008, 08:02:26
424.1750 ID=0707
424.4000 ID=0707
424.7000 ID=2707
Ja hoor, dat is heel goed mogelijk. Die 2 frequenties zijn een bekend "paar", dus wat je zegt klopt wel.
Bericht door: elsinga op 25 juni 2008, 12:48:56
Even een gokje: gisteravond hoorde ik dat setje frequenties vanuit Groningen/Hoogkerk loeihard. Lijkt er dus op dat het om zenders in Groningen gaat en dat die andere van Assen is.
Bericht door: elsinga op 27 juni 2008, 07:49:43
In Zaltbommel hoor ik 424.250 keihard met base ID 2307. Ook 001B uit Nieuwegein op 424.3625 komt redelijk door. Op 424.475 hoor ik 011C, maar die pakt hij maar soms. Op 424.550 hoor ik vrij hard base ID 201A. En op 424.6250 hoor ik 3007. 424.700 hoor ik ook, mar te ver in de ruis om een ID te zien.
En tot zover de berichten van uw verslaggever uit Zaltbommel. ;)
Bericht door: Michel-nl op 27 juni 2008, 19:00:39
mag je mij nog een keer uitleggen waarmee en hoe je die id's kunt zien?
Bericht door: Hunter op 27 juni 2008, 19:09:29
Citaat van: "Michel-nl"
Robert is een beetje (te) enthousiast met een testversie waarin je die id's kunt zien. In de thans te downloaden versie (2.4) kan dat dus nog niet...
Bericht door: Michel-nl op 27 juni 2008, 19:10:43
ah ik meende dat ook al gelezen te hebben idd, dacht misschien is er iets veranderd inmiddels :P
Bericht door: elsinga op 27 juni 2008, 20:29:42
Peter, als je de berichten niet op prijs stelt, dan wil ik daar best mee stoppen. Enthousiast is positief, TE enthousiast is dat tenslotte niet meer.  ;)
Bericht door: Hunter op 27 juni 2008, 20:33:44
Nouja het is een beetje tweeledig. Ik heb je die versie niet voor niets gestuurd, maar in zekere zin zit je nu mensen lekker te maken met iets wat ze nog niet kunnen gebruiken. Dat je enthousiast bent kan ik eigenlijk alleen maar toejuichen, dat is ook de bedoeling, maar ik denk dat je alle vergaarde informatie beter in een excel bestandje kunt zetten en tzt een keertje wereldkundig kunt maken :)
Bericht door: elsinga op 28 juni 2008, 08:12:08
Ook prima. Niet dat er veel bij zal komen, ben de komende tijd niet veel op pad met laptop. ;)
Bericht door: RenWvZ op 9 juli 2008, 20:12:43
Mobitex 424.4750 nunspeet richting harderwijk r/s 5/9+ BaseID: 2003
Ren van Zon
Bericht door: elsinga op 16 juli 2008, 17:40:44
Vandaag ging ik de kindertjes in Harlingen van de boot halen en heb op de heenweg de scanner even aangehad op 424MHz. Het resultaat: 2 frequenties in Friesland positief geidentificeerd. :)
424.5625 = Bolsward (op de A7 zelfs zonder antenne nog bijna te ontvangen en met antenne veel overspraak op 12.5kHz lager)
424.7000 = Sneek (idem)
In Harlingen of Franeker zal geen zender staan, want in Harlingen had ik vrijwel geen ontvangst (nou ja, Leeuwarden op 424.4250 en Bolsward ontving ik nog, maar niks sterkers). De door mij thuis gehoorde 424.3250 is op de rondweg van Sneek sterker dan zender Heerenveen, maar bij Bolsward wordt het al snel minder met die zender. Gokje: ergens in Gaasterland, richting Lemmer.
Oh ja, de laptop had ik niet mee, dus geen ID's. ;)
Bericht door: elsinga op 19 juli 2008, 08:34:26
Gisteren een training in Zaltbommel en gekeken of mijn vermoeden dat 424.325 vanuit Sneek en Heerenveen zuidelijker ligt. Wellicht ergens tussen Lemmer en Emmeloord. En dat klopt, hoogstwaarschijnlijk is het Emmeloord. ;) De zender is op de A6 rond Emmeloord erg sterk, maar nog zonder doorspetteren naar het naastgelegen kanaal. Doet me vermoeden dat de zender niet vlak langs de A6 staat, maar ergens in de binnenstad of ten NW van Emmeloord op een mast.
Bericht door: Hunter op 19 juli 2008, 14:35:02
Leuk, ik moet ineens denken aan mijn beklimming van de watertoren in Emmeloord. Deze staat aan de voet van een leuk, gezellig pleintje met wat winkels. Wellicht staat hij op die toren? Veel van dit soort netwerken stonden vaak gezamenlijk op 1 lokatie, volgens mij was ik daar destijds voor -het inmiddels opgedoekte- RWS-netwerk. Jammer, destijds kwam ik dus aardig wat Mobitex lokaties tegen, maarja als je alles van tevoren wist :(
Bericht door: elsinga op 19 juli 2008, 15:38:18
De enige plaats voor een zender *in* Emmeloord is inderdaad die kerktoren. Hangt heel wat in. ;) En die ligt ver genoeg van de A6 af om nog geen doorspetteren te geven, gok ik. :D
Bericht door: Hunter op 19 juli 2008, 16:09:19
Of was het een kerktoren... Kan ook, kerktorens, watertorens, vuurtorens, allen 1 laken een pak. Nergens een lift, altijd via 25 trappen omhoog met zware apparatuur... Onder de Markt, zo heette die straat volgens mij.
Bericht door: Hunter op 19 juli 2008, 18:20:36
Nou bij deze is het dan zo ver. PDW 2.5 is te dowloaden : http://www.gsm-antennes.nl/PDW/pdw.php?lang=nl (http://www.gsm-antennes.nl/PDW/pdw.php?lang=nl)
Bericht door: Mars op 19 juli 2008, 23:42:27
BaseID: 2100
inmiddels ook berichtjes  ;)
vr.gr.
Mars
Bericht door: Jeff2879203 op 27 juli 2008, 00:44:23
Ik heb hier nog een aantal BaseIDs die ik gevonden heb tussen de rit van Utrecht -> Drenthe/Assen. Ik wil graag wel een bevestiging als iemand mij 100% kan vertellen dat ze kloppen, als het zover is dat iemand ze (ook) zelf gevonden heeft!
Er kunnen volgens mij geen 2 BaseIDs zijn die hetzelfde zijn, want volgens mij zijn ze uniek, maar zoals hier onder heb ik 2 frequenties waarbij ik 0507 tegen ben gekomen.. dussss als iemand een bevestiging kan geven, dan hoor ik het wel.
424.1750            0507                  Rond Assen
424.3125            040A                  Rond Zwolle
424.3125            050B                  Rond Assen
424.4000            0507                  Rond Assen
424.4750            2003                  -
424.5625            0412                  Rond Zwolle
424.7000            2506                  Rond Assen
(Veel is tussendoor vanaf de A28 opgevangen van Utrecht -> Assen)
Groeten
Jeffrey J
Bericht door: Hunter op 27 juli 2008, 02:51:57
Citaat van: "jeffrey1200"
Dat kan wel. Het ID is inderdaad uniek voor het basistation, maar niet voor zijn kanalen. 1 basisstation kan uit 2 kanalen bestaan, die hebben dan beiden hetzelfde ID hebben.
Meer info : viewtopic.php?p=129080#p129080 (http://www.scannerforum.nl/viewtopic.php?p=129080#p129080)
Bericht door: elsinga op 27 juli 2008, 19:00:05
Dat setje .175/.400 zal Groningen zijn, .700 is Assen. Zie pagina 3 van deze thread. ;)
Bericht door: Jeff2879203 op 28 juli 2008, 22:43:27
Lijkt me sterk aangezien ik een ander BaseID heb, maar ik had nog niet de pagina's tussendoor gelezen. Assen(Centrum) en Veenhuizen ligt niet ver van elkaar, maar het kan ook zijn dat er gewoon zenders zitten bij Veenhuizen met een laag vermogen en Assen met een laag vermogen.. zou anders niet het verschil in BaseIDs verklaren OF n van ons zou het verkeerd moeten hebben.. maar dat lijkt me ook sterk....
Peter kan jij niet alle IDs in je eerste post zetten die hier geplaatst zijn?
Jeffrey
Bericht door: Hunter op 29 juli 2008, 01:32:46
Dat kan, maar "rond Assen" noem ik geen concrete lokatie, sorry.
Bericht door: Jeff2879203 op 29 juli 2008, 11:03:56
Rond Assen heb ik vanuit het centrum buiten de auto gevangen, maar ik bedoel met lokatie waar ik de zender heb gehoord en niet waar de zender zit, dus als ik zeg "Rond Assen" moet de zender zich binnen een bepaald gebied rond Assen bevinden..
Jeffrey
Bericht door: Hunter op 29 juli 2008, 12:04:12
Dat begrijp ik ook wel, maar is voor mij niet concreet genoeg om in de lijst op te nemen. Als je bedenkt dat ik zelf over het algemeen zoek tot ik de antenne zie staan dan moet je al blij zijn dat ik lokaties van anderen in de lijst opneem ;)
Weet je wat het probleem is, vroeger was het ook een puinhoop met frequenties, tooncodes en nu ook een klein beetje met capcodes. Er wordt al snel een conclusie ergens aan verbonden terwijl het vaak heel anders kan blijken te zijn. Radiosignalen laten zich niet zo gemakkelijk voorspellen, ik heb al aardig wat vreemde dingen meegemaakt. Laatst peilde ik nog een zender vanuit Den-Haag Zuid, het signaal leidde mij tot Hoek van Holland en uiteindelijk bleek hij aan de andere kant van het water te staan, waarschijnlijk ergens op de Maasvlakte. En dat terwijl andere zenders die nota bene in Den-Haag zelf staan minder hard waren, dus zeg het maar. Sommige zenders staan hoog, anderen laag, soms een kleine antenne of juist een grote, laag vermogen of juist hoog. In Rotterdam ben ik een soort "opvulzendertje" tegengekomen, laag vermogen, kleine antenne en dat ding heeft echt een gering bereik. Als je zo'n zender als referentie zou nemen voor andere zenders dan zou je al veel te snel denken dat je in de buurt bent, terwijl hij in werkelijkheid wel kilometers verder kan staan.
Daarom had ik eigenlijk gehoopt op support van mensen met enige ervaring met peilen, maar de input valt tot dusver helaas een beetje tegen, misschien komt dat ooit nog.
Bericht door: Jeff2879203 op 29 juli 2008, 16:40:30
Sorry Peter ik begrijp je, maar ik dacht als je nou alles bij eerste post zet, misschien met vraagtekens erbij dan hoeven mensen niet alle pagina's door te lezen als er een nieuw BaseID gevonden is als die al door iemand anders gevonden is.
Sorry nogmaals. Ik heb helaas ook geen verstand van peilen, dus dat is jammer.
Jeffrey
Bericht door: elsinga op 29 juli 2008, 18:25:11
Mijn conclusie over de zenders in Groningen was omdat ik ze op de Eemsgolaan (tegen Hoogkerk aan) op de begane grond met verzwakker aan nog op S( binnenkreeg op de porto. Ik zou het gokje wel willen uitbreiden met de gedachte dat ze de zenders best eens op het Gasunie gebouw kunnen hebben staan... Maar dat kan ik binnenkort wel eens beter peilen, want vanaf 1 september zit ik daar in het gebouw. ;)
Bericht door: Hunter op 30 juli 2008, 09:18:11
Oh nee dat geloof ik wel, Groningen is Groningen, zolang het maar geen "in de buurt van Groningen" is :)
Heb de lijst geupdate, staan nog wel wat vraagtekens tussen maar misschien krijgen we daar ooit nog meer zekerheid over...
Bericht door: Erik op 2 augustus 2008, 08:14:31
Staat er ergens een overzicht lijst van de gevonden ID's ?
Bericht door: Hunter op 2 augustus 2008, 08:21:31
Citaat van: "Erik"
Uh op pagina 1, eerste posting, ofterwel de startposting? :)viewtopic.php?p=126180#p126180 (http://www.scannerforum.nl/viewtopic.php?p=126180#p126180)
Bericht door: Erik op 2 augustus 2008, 09:51:35
oh had ik niet gezien.
Nu wel.
Bericht door: Arle op 3 augustus 2008, 09:06:21
Op 424.7625 krijg ik de volgende ID's door;
0106
2006
2104
2106 (R'dam Centrum)
2107
Op 424.7000:
2119 (R'dam IJsselmonde)
Op 424.5500:
0100
0108 (Den Haag Leyweg)
0308
Op 424.3625:
011A (Vlaardingen
0112
Lokatie: Rotterdam-Centrum, vrij hoog.  :)
Bericht door: Erik op 3 augustus 2008, 09:46:51
Dat moet wel als je Den Helder hoort.
2104=Den Helder
Bericht door: Arle op 3 augustus 2008, 11:23:15
Citaat van: "Erik"
2104=Den Helder
En dat met een rubberduck en slecht weer...  :)
Bericht door: Hunter op 3 augustus 2008, 11:39:58
Citaat van: "Arle"
0106
2006
2104
2107
Op 424.7000:
Op 424.5500:
0100
0308
Op 424.3625:
011A (Vlaardingen
0112
Uh meerdere ID's tegelijk op 1 frequentie? Ik ben eerder bang dat je last hebt van biterrors waardoor hij soms verkeerde ID's weergeeft. Immers, als jij in Rotterdam-Centrum zit en er staat een site bij jou om de hoek, dan is dat signaal zo sterk dat je nooit iets anders kunt horen, zeker geen Den-Helder :) Het feit dat veel ID's die jij op 1 frequentie hoort erg op elkaar lijken versterkt mijn vermoeden, in veel gevallen hoeft er maar 1 bitje om te vallen om een ander ID te krijgen :
0106 binair : 000001-000110
2006 binair : 010100-000110
2104 binair : 010101-000010
2106 binair : 010101-000110
2107 binair : 010101-000101
Ik zal eens kijken of er wat aan te verbeteren valt, bij mij staat ie soms ook te klapperen op bepaalde frequenties, maar zeker als je een sterk signaal hebt mag dat eigenlijk niet voorkomen...
Bericht door: Arle op 3 augustus 2008, 12:08:19
Het kan ook door storen van andere PC's zijn... Er staan er hier nogal wat en het geluid klinkt niet superzuiver. Aan de andere kant.. De zender staat volgens mij op het EMC en als dat klopt, zit ik op ooghoogte, nu en zou het geen probleem moeten zijn... De berichten komen overigens 99,9% goed door, maar ook in de berichten valt wel eens een bitje om, terwijl het thuis wel 100% is. Dus ik houd het bij de storingen van de andere PC's. Hey, jammer... Had Den Helder wel leuk gevonden om te halen.  :?
Bericht door: Tom(zulu10) op 3 augustus 2008, 12:36:46
Deze heb ik nog gevonden:
424.1375 Base ID 2104
424.1125 Base ID 010C
PS: ik krijg alleen op deze frequentie 424.5875 meerdere Base ID`s
Bericht door: Hunter op 3 augustus 2008, 13:19:05
Citaat van: "Arle"
Rotterdam-Centrum staat volgens mij op het WTC. In elk geval staat daar een antenne en is het signaal daar kogelhard. Echt hartje centrum dus, EMC ligt daar een stuk buiten. Rotterdam-West staat op een van die hoge kantoorgebouwen bij het Marconiplein.
Overigens even wat minder goed nieuws, ik heb zo'n donkerbruin vermoeden dat er helemaal geen ene k**** klopt van die ID's. Ik vond het al zo vreemd dat veel ID's met 00/01/02 begonnen en vervolgens ineens een hoop met 20/21/22/23. Weliswaar is dat een hexadecimale weergave (die laatste 4 zouden decimaal 32/33/34/35 zijn) maar ik zie er geen logica in, waar zijn al die tussenliggende Area's dan? Het ID wat PDW weergeeft is namelijk een combinatie van het AreaID en het BaseID, waarbij de eerste 2 de AreaID zijn. Ik heb helaas ook totaal geen referentie, geen bronnen en geen connecties die me iets verder op weg kunnen helpen, dus het is allemaal gokken en gissen. Nu laat ik de bitjes iets anders inlezen en krijg ik zulke ID's te zien :
nieuw (oud) = Lokatie
021A (010D) = Alphen a/d Rijn
0306 (0103) = Gouda
0310 (0108) = Den-Haag Leyweg
0314 (010A) = Rotterdam-Oost
0336 (011B) = Zoetermeer
0313 (210C) = Rotterdam-West
0303 (2101) = Delft
030D (2106) = Rotterdam-Centrum
0333 (2119) = Rotterdam-IJsselmonde
0403 (2201) = Leiden
0413 (2209) = Den-Haag CS
0415 (220A) = Leidschendam
Dat lijkt me persoonlijk iets logischer, maar ik ben er nog niet helemaal uit. Zou wel jammer zijn als we helemaal overnieuw kunnen beginnen, de 'oude' ID's zijn helaas niet om te rekenen naar de 'nieuwe' :(
Bericht door: Hunter op 3 augustus 2008, 13:30:19
Citaat van: "Tom(zulu10)"
Interessant, misschien is dat een lokaal zendertje ofzo, want ik hoor hem nu ook voor het eerst op mijn onlangs door Ren aangepaste Condor-3000, met daaraan toch wel een redelijke antenne. Als jij hem een paar kilometer verderop ook hoort dan staat hij misschien ergens in Rotterdam-Noord ofzo, kan me alleen niet herinneren dat ik hem eerder heb gehoord tijdens een van mijn zoektochten. Ik zie in elk geval het (oude) ID 0105.
Bericht door: Tom(zulu10) op 3 augustus 2008, 13:43:50
Misschien ergens in Rotterdam-Overschie?
Bericht door: Hunter op 3 augustus 2008, 13:48:34
Pak je scanner en stap op de fiets ;)
Bericht door: Tom(zulu10) op 3 augustus 2008, 14:01:42
Dat zou ik kunnen doen maar ik heb geen idee hoe ik moet uit peilen om te zien waar die zender dan staat,dus laat ik dat maar aan de specialisten over. :)
Bericht door: Hunter op 4 augustus 2008, 06:47:39
Zojuist heb ik de lijst aangevuld met de 'nieuwe' ID's. Of die nu wel kloppen weet ik niet, ik heb totaal geen referentie. Het puzzelen met de bitjes die de buurkanalen aangeven was velen malen gemakkelijker, als er ook maar 1 bitje niet klopt dan verschijnen er totaal onlogische kanalen, dus in zo'n geval weet je direkt of je goed zit of niet. Maarja in wat voor orde van grootte ik me die ID's moet voorstellen is me een raadsel, dus misschien kloppen deze nieuwe ook wel niet.
Anyway, wie deze nieuwe weergave wil testen kan zich via email bij mij melden. Tevens zou deze update iets minder moeten klapperen qua Network- en BaseID in geval van minder goede signalen of de verstoring ervan.
Bericht door: Arle op 4 augustus 2008, 10:52:19
424,6250 MHz   2103    (????)   Europoort/Maasvlakte = 0307 nieuw
Bericht door: Erik op 4 augustus 2008, 11:24:57
Is er nog meer data leesbaarder te maken ?
Bericht door: Hunter op 5 augustus 2008, 09:40:47
Misschien wel een goeie, daar ben ik eigenlijk nog niet geweest. Voor hetzelfde geld staat ie wel op van Leeuwen Buizen, alleen had ik hem dan wel wat harder verwacht. Misschien kunnen anderen 424.5875 eens in de gaten houden als ze toevallig over het Kleinpolderplein rijden?
Citaat van: "Erik"
Daar zou ik niet op rekenen, PDW geeft de data weer zoals het verzonden wordt en de inhoud (en daarmee tevens de onleesbaarheid) van die data verschilt per gebruiker.
Nu de ID's toch gaan veranderen, misschien is het een idee om ze volledig decimaal weer te geven? Area en Base zijn beiden 6 bits, dat betekent een HEX maximum van 3F3F en decimaal 6363.
Ook kan Area en Base als geheel worden weergegeven, nu zijn het steeds 2 afzonderlijke 2-tallen die als 4-tal worden gepresenteerd. Ik zal wat voorbeelden uiteen zetten :
OUD    NwHEX  NwDEC  TotHEX  TotDEC   Lokatie
2209   0413   0419     113     275    Den-Haag (CS)
210C   0319   0325      D9     217    Rotterdam-Noord
2101   0303   0303      C3     195    Delft
010D   021A   0226      9A     154    Alphen a/d Rijn
011B   0336   0354      F6     246    Zoetermeer
011A   0334   0352      F4     244    Vlaardingen
2201   0403   0403     103     259    Leiden
0103   0306   0306      C6     198    Gouda
010A   0314   0320      D4     212    Rotterdam-Oost
020B   0416   0422     116     278    Den-Haag (Scheveningen-Haven)
2106   0319   0325      D9     217    Rotterdam-Centrum
0108   0310   0316      D0     208    Den-Haag Zuidwest
220A   0415   0421     115     277    Leidschendam
210B   0317   0322      D6     214    Rotterdam-Feijenoord
2119   0333   0351      F3     243    Rotterdam-IJsselmonde
0109   0212   0218      92     146    Sassenheim
Ik ben benieuwd wat jullie voorkeur geniet??? Opzich lijkt die laatste wel aardig, maar dan zou je nooit BaseID 1 kunnen krijgen, want er vanuit gaande dat er geen AreaID 00 bestaat zou het laatste ID (in de huidige weergave) dus 0101 zijn en dat geeft weer een HEX minimum van 41 en Decimaal van 65.
Persoonlijk zou ik dan de middelste, nieuw decimaal, het mooiste vinden, aangezien ik denk dat niet iedereen een hexadecimale weergave mooi vindt. En om daar nu weer een keuzemogelijkheid van te maken dat vind ik eigenlijk weer een beetje overdreven...
Bericht door: elsinga op 5 augustus 2008, 18:38:53
Ik ben voor NwHex, dan zie je in 1 getal de area en Base. ;)
Bericht door: hamateur op 5 augustus 2008, 21:36:16
Zelf geef ik ook de voorkeur aan NwHex.
Ik heb een paar programma's die oa trunking kunnen volgen geven het ook in hexadecimaal weer.
Bericht door: Hunter op 6 augustus 2008, 08:33:47
Laat ik maar hopen dat nog niemand hier speciaal tijd voor heeft uitgetrokken, want daar staat hij zeker niet. Niet alleen heb ik dat zelf geconstateerd, ik heb hem nu al een poosje meedraaien en ik zie voornamelijk berichten vanuit Kennemerland  :?
Heel apart allemaal. Mogelijkerwijs staat ie dus veel verder dan we denken, maar dan is het wel weer vreemd dat hij zo 'breed' in de buurtabellen staat :
- Zoetermeer
- Den-Haag CS
- Alphen a/d Rijn
- Den-Haag Zuidwest
- Rotterdam-IJsselmonde
En hier weer niet :
- Leiden
- Gouda
- Leidschendam
Ik heb sowieso een beetje mijn twijfels bij sommige buurtabellen, sommigen zijn zo lang met kanalen waarnaar je nooit in 1x kan overschaken, logisch gezien, misschien een soort "achterstallig onderhoud"?
Overigens is dit het enige kanaal waar ik een dusdanig zwak signaal helemaal schoon zonder enige verstoring hoor, zoveel wordt dit kanaal dus niet gebruikt, dus naar welke 424.5875 die sites nu precies verwijzen is me een groot raadsel....
Bericht door: Hunter op 6 augustus 2008, 09:43:30
Beste mensen,
Nog even wil ik terugkomen op de fout mbt de BaseID's. Ik sprak namelijk iemand en die had een ander stukje software (ben de naam even kwijt) en die gaf warempel dezelfde ID's aan als PDW in eerste instantie, de FOUTE dus.
Dat maakt mijn sprong misschien wat twijfelachtiger, maar ik zal even uitleggen waar het fout is gegaan. Misschien dat niet iedereen het begrijpt, maargoed ik probeer het in elk geval.
Mobitex werkt net als P2000 met zogenaamde frames (datablokken). Elk frame heeft een 56-bit header, bestaande uit :
Frame Sync (16 bits)
Bit Sync (16 bits)
BaseID (6 bits)
AreaID (6 bits)
Control Flags (4 bits)
Parity (8 bits)
Wat die Control Flags doen weet ik niet precies, maar dat doet ook even niet zoveel ter zake.
De Frame (Network) Sync is bij ons EB90 en de Bit Sync is CCCC voor basis 3333 voor mobiel.
Goed, ik begon weliswaar op de juiste plek met inlezen, maar ik deed (door een stomme, niet nader uit te leggen fout) het volgende :
BaseID (5 bits)
AreaID (6 bits)
Parity (9 bits)
Ik begin met een bit te weinig en had op het einde 1 bit teveel in de Parity. Dat betekent dus dat het laatste bitje van de BaseID ineens het MSB (het belangrijste/hoogste bitje) van de AreaID werd. Daarom zag je soms ineens hele rare/hoge AreaID's, paar voorbeelden :
0001=Utrecht-Uithof
0103=Gouda
020B=Scheveningen
2019=Amersfoort
2100=Alkmaar
220A=Leidschendam
2319=Maastricht
Of Area 00 daadwerkelijk bestaat, dat zou misschien nog wel kunnen, maar die sprong naar 20 vond ik al zo vreemd. Maar als je nu die fout ernaast legt dan is een AreaID van 100000 (binair) waarbij de 1 eigenlijk bij het BaseID hoort, hexadecimaal 20, dus dat klopt exact!!!
Zo kun je verder door gaan met rekenen en valt alles in elkaar.
Hoe het dan in godsnaam kan dat iemand anders blijkbaar exact dezelfde fout maakt weet ik niet, toeval bestaat niet zou je bijna zeggen, maar wat hij nu laat zien is ook vele malen logischer. Ik heb tot dusver alleen nog ID's gezien waarvan het AreaID met 02/03/04 begint en dat is mijns inziens een stuk aannemelijker dan die rare +20 sprongen.
Kijk nog even naar Rotterdam (oud) :
010A=Rotterdam-Oost
010C=Rotterdam-West
2106=Rotterdam-Centrum
210B=Rotterdam-Feijenoord
210C=Rotterdam-Noord
2119=Rotterdam-IJsselmonde
En Rotterdam (nieuw) :
030D=Rotterdam-Centrum
0314=Rotterdam-Oost
0317=Rotterdam-Feijenoord
0318=Rotterdam-West
0319=Rotterdam-Noord
0333=Rotterdam-IJsselmonde
Als dat er niet veel beter uit ziet dan weet ik het ook niet.
Dan nog even wat antwoorden :
Die mag je even uitleggen, want dat zie je toch ook in de oude situatie en ook als NwDec?
Citaat van: "hamateur"
Ja dat had ik vroeger ook volgens mij bij Etrunker (EDACS). Ik heb ook niet voor niets in eerste instantie voor HEX gekozen, aangezien de bitsync (CCCC/3333) en network/framesync (EB90) eveneens HEX zijn. Maarja de 'nummering' van sites is toch iets anders en de lengte verandert niet ineens (3F3F of 6363), in tegenstelling tot de weergave als totaal, daarbij zijn de verschillen een stuk groter. Zelf twijfel ik tussen NwDec en NwHex waarbij ik zelf denk dat decimaal voor het grote publiek begrijpelijker is, hoewel het natuurlijk weinig uitmaakt of je nu 021A of 0226 te zien krijgt en eventueel opneemt in de base-ids.txt.
Bericht door: elsinga op 6 augustus 2008, 18:41:43
Maar de oude situatie is de foute, dus daar kies ik niet voor. ;) En Decimaal voor een binair getal is niet handig, krijg je ineens combi's die na 9999 doortellen op 100100 en dat verspringt. Terwijl het in Hex altijd 4 tekens blijft.  :) Dus NwHex.
Bericht door: Arle op 6 augustus 2008, 23:26:55
Alleen klopt de lijst op de eerste pagina volgens mij niet helemaal;
Frequentie    BaseID   Nieuw    Lokatie
424,0875 MHz   2100    (0201)   Alkmaar
424,3625 MHz   001B    (0201)   Nieuwegein
424,1125 MHz   210C    (0319)   Rotterdam-Noord
424,5375 MHz   2106    (0319)   Rotterdam-Centrum
Bericht door: Wopper op 7 augustus 2008, 05:57:55
Helemaal mee eens!
Bericht door: Hunter op 7 augustus 2008, 08:09:52
Citaat van: "Wopper"
Helemaal mee eens!
Uh volgens mij had ik het vrij duidelijk uitgelegd, maar ik zal het nogmaals proberen.
Het AreaID en BaseID zijn 2 aparte gegevens die ik als 1 waarde weer laat geven. Beiden zijn ze 6 bits en dat betekent dus dat ze beiden een decimaal maximum van 63 hebben en een hex max van 3F. Weergegeven als 1 ID is dat dus een maximum van DEC-6363 of HEX-3F3F, graag enige uitleg hoe dit kan 'verspringen', want ik zie het niet hoor... Bij lagere waardes waar bijvoorbeeld 1-1 zou verschijnen komt 0101, er is altijd een voorloopnul per ID indien nodig, zowel DEC als HEX.
Samengevat zal het totale ID -die ik simpelweg BaseID noem- dus ALTIJD uit 4 cijfers cq karakters bestaan.
Als ze als 1 geheel (dus als zijnde 12 bits) worden weergegeven dan komt het er dus uit te zien zoals in de laatste 2 kolommen. Ook dan zouden er voorloopnullen voor kunnen komen, maar de verschillen zijn dan wat grilliger, het absolute maximum (uitgaande van AreaID-01 en BaseID-01) is dan DEC-65 / HEX-41 en het maximum DEC-4095 / HEX-FFF, dat is minder mooi, dus laten we dat sowieso maar vervallen, een en ander was slechts ter illustratie.
Bericht door: Arle op 8 augustus 2008, 10:11:53
Weer een nieuwe (nog niet uitgepeilde) zender;
424.1125 0318 (010C OUD) Geen idee, omg. Rotterdam
424.1375 0309 (2104 OUD)  Vermoed Spijkenisse of Rotterdam-Zuid
Bericht door: elsinga op 8 augustus 2008, 10:40:35
Peter,
Noem mij maar puritein, maar als je iets vanuit binair stelsel om gaat zetten naar iets leesbaars is voor mij Hex de eerste keuze. ;) Door jouw verduidelijking zal er inderdaad max 6363 decimaal uitkomen, dus dat scheelt al. :)
Ik zie dus het liefst hexadecimaal, maar als jij (of anderen) liever decimaal willen, prima.
Bericht door: Hunter op 8 augustus 2008, 13:00:28
Citaat van: "Arle"
010C = 0318(nieuw) = Rotterdam-West (Marconiplein)
Die andere heb ik inderdaad wel ontvangen en leek mij erg hard in Schiedam. Spijkenisse lijkt me dan een klein beetje ver, kom jij weleens langs dat gebouw langs de A15 waarop heel veel antennes van de politie stonden? De Ruit-kanalen stonden daar onder andere. Anders misschien Hoogvliet, hoewel ik ook wel een zender in Spijkenisse verwacht. Rij anders een keer via Hoogvliet-Spijkenisse naar huis ;)
Misschien begint het er langzaam op te lijken dat ik tegen een hexadecimale weergave ben, maar als dat zo was dan had ik er niet aan moeten beginnen in the first place, dus dat is het niet. Ik snap achter sommige argumenten niet. Jij hebt het nu over het omzetten van binair naar iets "leesbaars", maar je kunt het natuurlijk ook andersom zien. Ik heb enige ervaring met de nummering van basisstations en de officiele benummering daarvan is vaak niet hexadecimaal maar gewoon decimaal. Als een site nu eens gewoon het decimale nummer 63 heeft dan zal er toch echt binair 111111 verzonden moeten worden (wat wil je anders verzenden?) en ik snap niet waarom iets wat als 111111 is verzonden perse ineens als 3F moet worden weergegeven. Het eerdere argument van dat "verspringen" vond ik eerlijk gezegd begrijpelijker, maar doet -in dit geval- dus niet ter zake.
De grote vraag is dus niet alleen wat we willen zien, maar ook wat er is verzonden. Vaak wordt het inderdaad HEX weergegeven omdat dat -hoe groter de getallen worden- korter is en minder snel 'verspringt' maar als de nummering bij wijze van spreken slechts tot 20 loopt dan maakt dat natuurlijk ook niet veel uit. 1 t/m 20 of 1 t/m 14(hex)
Maargoed ik zal het laten voor wat het is, aangezien er verder blijkbaar geen voorstanders zijn van een decimale weergave...
Het wordt steeds vreemder, want de software in kwestie laat bij mij gewoon de 'nieuwe' ID's zien, het scheen een oudere versie te zijn geloof ik, laten we dit verhaal maar even vergeten, ik ben er inmiddels voor 100% van overtuigd dat het nu gewoon klopt.
Bericht door: elsinga op 8 augustus 2008, 18:18:02
Ik heb de laatste alpha van PDW nog even aangeslingerd en heb de volgende ID's opgeduilekd:
Drachten   BaseID: 0A16 (oud: 050B)
Heerenveen BaseID: 0A0F (oud: 2507)
Leeuwarden BaseID: 0A10 (oud: 0508)
Sneek BaseID: 0A1B (oud: 250D)
De rest ontvang ik hier op de begane grond niet. ;) Wat me wel opvalt is dat de ontvangst veel sneller stabiel is, wat Peter ook al mailde. :)
Bericht door: Michel-nl op 9 augustus 2008, 09:17:41
euh heb ik iets gemist? is er al weer een andere versie van 2.5?
Bericht door: Hunter op 9 augustus 2008, 09:55:40
Ik denk het : viewtopic.php?p=129643#p129643 (http://www.scannerforum.nl/viewtopic.php?p=129643#p129643)
Bericht door: Michel-nl op 9 augustus 2008, 10:00:36
ja ok het betreft een test versie die een aantal mensen van je hebben gekregen, ik snap et :)
Bericht door: Hunter op 10 augustus 2008, 08:24:57
Ahum, die 424.5875 (oud:0105 / nieuw:020A) blijkt dus in Haarlem te staan  :oops:
Bericht door: Arle op 10 augustus 2008, 11:29:15
Ik denk dat ik de lokatie van 0307 heb gevonden:
Boven op het gebouw van EBS Europoort,  51°57'4.65"N   4° 7'24.07"O Google Earth
Bericht door: Hunter op 10 augustus 2008, 11:59:28
Citaat van: "Arle"
Ik neem aan dat dat gelijk staat aan deze lokatie op Google.Maps : http://maps.google.nl/maps?q=51+57+04+04+07+24&z=12 (http://maps.google.nl/maps?q=51+57+04+04+07+24&z=12)
In dat geval is het inderdaad niet zo vreemd dat hij kogelhard was in de Hoek :)
Bericht door: Arle op 10 augustus 2008, 20:35:21
Citaat van: "Arle"
Klopt inderdaad!  :)
Maar voor de duidelijkheid: heeft er iemand toevallig een foto van een mast van RAM / Mobitex? Geen idee hoe dat er uit ziet.
Bericht door: Hans013 op 17 augustus 2008, 20:30:58
Volgens mij was deze nog niet bekend:
424.2500 Tilburg BaseID 070F
Bericht door: Michel-nl op 17 augustus 2008, 20:32:59
Citaat van: "Arle"
Citaat van: "Arle"
Klopt inderdaad!  :)
ik zal die van drachten wel es op de foto kieken.
Bericht door: Hunter op 18 augustus 2008, 03:41:46
Citaat van: "Arle"
Ik weet niet wie er een beetje bekend is met Kathrein antennes, maar het zijn gewoon dezelfde sprieten als die voorheen gebruikt werden voor de analoge portofoonkanalen van de politie. Ik heb ze in 5dB en 0dB uitvoeringen gezien, wellicht wordt de 3dB variant (tussenmaatje) ook gebruikt. Zo bijzonder is die antenne dus niet, hij kan gebruikt worden tussen 440 en 470 MHz en de 400-430 variant ziet er exact hetzelfde uit. Bij het zien van zo'n antenne kun je er dus niet blindelings vanuit gaan dat hij van RAM Mobile is, tenzij het signaal natuurlijk bikkelhard is :)
Bericht door: elsinga op 18 augustus 2008, 06:48:04
Ik reed afgelopen week toevallig door Heerenveen en ter hoogte van de grote betonnen KPN zendmast aan de KR Poststraat spetterde het Mobitex signaal dwars over alle kanalen heen. Dat was voor mij een aardige indicatie. ;)
Bericht door: edwinlwd op 27 augustus 2008, 22:55:49
Bij deze een lijstje van buren van kanaal Leeuwarden.
 [LIST OF NEIGHBOUR CHANNELS BaseID:0A10]
 Neighbour-01 : 424.1125 MHz / 414.1125 MHz
 Neighbour-02 : 424.1375 MHz / 414.1375 MHz
 Neighbour-03 : 424.1750 MHz / 414.1750 MHz
 Neighbour-04 : 424.3375 MHz / 414.3375 MHz
 Neighbour-05 : 424.3625 MHz / 414.3625 MHz
 Neighbour-06 : 424.4750 MHz / 414.4750 MHz
 Neighbour-07 : 424.5625 MHz / 414.5625 MHz
 Neighbour-08 : 424.7000 MHz / 414.7000 MHz
Hier wordt kanaal Leeuwarden 24 uur per dag gevolgd met wel intressante dingen. Mijn vermoeden is dat er vlak bij Leeuwarden nog een kanaal hangt waar wagens in Leeuwarden gegevens van krijgen.
Bericht door: elsinga op 5 september 2008, 11:55:03
Ik heb net (vanuit het Gasunie gebouw) even het loeiharde signaal van de gekoppelde Groninger cellen geprobeerd te ontvangen. Base ID komt door als 0A0E op 424.1750 en 424.400. Verder hoor ik wel steeds de (lange) dataruis, maar ik krijg geen berichten door... Alle vinkjes staan aan, dus ik zou heel veel Network verkeer moeten zien...
Ik dacht dat dat aan mij lag, maar iemand uit Heerenveen mailde me dat hij problemen had met het decoderen en dat klonk nogal als wat ik ook heb. Is er wat gewijzigd bij RAM?
Bericht door: aaldert op 6 september 2008, 09:37:53
Heb je er nog steeds last van?
Vandaag ( zaterdag ) hoor ik nog steeds die "lange" dataruis,, maar kan lees niks op PDW....
Bericht door: elsinga op 6 september 2008, 09:51:24
Ik weet het niet, kabeltje ligt nog in Groningen.  :oops:
Bericht door: aaldert op 6 september 2008, 10:34:15
ach ja kan gebeuren;)   was wel ff benieuwt of er ook meerderen zijn in de omgeving hrveen die die lange dataruis horen, maar niet lezen.
anders moet ik de oorzak bij mijzelf opzoeken...
Bericht door: Hunter op 6 september 2008, 11:04:08
Citaat van: "aaldert"
Ik ben echt benieuwd waar dit over gaat. Is dit nu op 1 zender, of meerderen, wat voor datasignaal is dat precies, is er een opname van te maken? Wie via de compoort decodeert kan er ook een digitale opname mee maken die ik kan gebruiken om verder uit te pluizen in mijn ontwikkelomgeving. Zo'n opname kun je starten met SHIFT-ALT-R en vervolgens een bestandsnaam op te geven. Pas wel op, deze bestanden groeien erg snel. Alles, dus ook ruis, wordt digitaal opgeslagen. Ik ben erg geinteresserd in zo'n "recording" in  combinatie met een geluidsopname.
Bericht door: aaldert op 6 september 2008, 17:08:57
Hoi
Ik heb er ff een filmpie van gemaakt..
Ik heb hem op de frequentie van heerenveen,, 424.362
Ik zelf hoor deze ruis alleen op deze frequentie...
http://nl.youtube.com/watch?v=1GHNKXC7fu8
Bericht door: Henk fryslan op 6 september 2008, 17:15:53
Zit op de zelfde freq 424.362 Heerenveen mee telezen maar komt hier glas helder door de data.
Gr Henk.
Bericht door: Hunter op 6 september 2008, 17:17:59
Dat klinkt als een soort storing. Ik dacht eerder dat het ging om data die niet gedecodeerd werd. In dat geval hoeven er geen verdere opnames gemaakt te worden, PDW kan hier niet zoveel mee.
Wat het wel is? Ik weet het niet. Wel weet ik dat C2000 soortgelijke verstoring kan geven en daarnaast hebben we tegenwoordig ook het commerciele TETRA netwerk van MCCN en hier in Haaglanden zit in diezelfde frequentieband ook nog eens een TETRA netwerkje van de HTM. Dat soort spul kan aardig wat storing geven, zeker als TETRA dichterbij staat dan de RAM zender. Wat het in dit geval is durf ik niet te zeggen, het is natuurlijk merkwaardig dat verschillende mensen hetzelfde lijken te ervaren...
Henk heeft hier blijkbaar geen last van. Robert, hoor jij hetzelfde als wat in dat filmpje te horen is?
Bericht door: Michel-nl op 6 september 2008, 19:24:05
hier in Boornbergum ook geen enkel last van de storing op die freq.
Bericht door: elsinga op 6 september 2008, 20:21:31
Ik zat te luisteren op de cellen van Groningen en kreeg bij beide wel het BaseID mee, maar verder geen data. Het audiosignaal klonk wel zoals normaal, dus niet zoals het filmpje van Aaldert.
Wellicht zijn het de instellingen... ik gebruikte voor het eerst die laptop. Maar dan is het raar dat de BaseID wel doorkomt maar verder helemaal niks.
Bericht door: aaldert op 6 september 2008, 20:22:09
hmm.. morgen maar fff door heerenveen rijden. of ik wel ergens in hrveen signaal kan krijgen...
Bericht door: elsinga op 7 september 2008, 08:47:02
Zender staat op de KPN mast aan de KR Poststraat, volgens mij. ;)
Ik zal maandag of zo in Groningen nog wel even wat gaan spelen, als ik tijd heb.
Bericht door: aaldert op 7 september 2008, 13:31:34
vandaag dus ff door heerenveen geweest,, maaar ook al sta ik 15 meter van de kpn mast af.. ik hoor steeds die storing... :(
Bericht door: Michel-nl op 7 september 2008, 13:49:22
dan vrees ik dat het em in jouw scanner ligt.
Bericht door: aaldert op 7 september 2008, 14:07:28
sja dat d8 ik al... bale
maar het landelijk p2000 kan die wel ontvangen,, maja het is niet anders
Bericht door: edwinlwd op 11 september 2008, 21:32:32
Base id van de 424.5625 Bolsward/Sneek: 0A21
Bericht door: Hunter op 12 september 2008, 01:50:56
Citaat van: "edwinlwd"
Bolsward of Sneek?
Bericht door: elsinga op 12 september 2008, 08:03:19
Bolsward of Sneek?
Ik heb die frequentie als Bolsward in de lijst staan. Sneek is 0A1B. Het lijkt alsof Friesland 0Axx is. ;)
Bericht door: BlackBox op 19 september 2008, 20:49:59
Zojuist even gespeeld met 2.51 en Mobitex, vanuit het Gooi waarneembaar nieuwe ID's (ivm lijst in opening van deze thread):
424,0875 0137
424,5375 011D
424,4750 0107
424,1125 0202
424,3250 0207
424,5500 0208
424,7750 0208
424,7625 0210
424,5625 0233
424,1375 020D
424,3125 0914
Bericht door: Hunter op 30 augustus 2009, 15:21:34
Nu was ik toch enigzins in de veronderstelling alle zenders in mijn direkte omgeving in kaart te hebben gebracht, maar tijdens een ritje naar/door Den-Haag werd gisteren mijn verbazing geschetst door een sterk, onbekend BaseID. Na een korte zoektocht bleek deze te staan op "de blauwe tegeltjes flat" aan de Beeklaan in Den-Haag, vroeger tevens een EDACS opstelpunt.
424.4375 Den-Haag Beeklaan, BaseID:041A
Iemand met een beetje plaatselijke kennis enig idee hoe ik die omgeving het best kan noemen, Seghbroek?
Overigens ben ik even creatief geweest in Google Maps en heb de gevonden lokaties even toonbaar gemaakt :
KLIK HIER (http://maps.google.com/maps/ms?source=s_q&hl=nl&geocode=&ie=UTF8&msa=0&msid=107486386994303181657.00047257888740b9dd47c&ll=52.09807,4.66507&spn=0.679117,1.399384&z=10)
Ik heb er meer uitgepeild dan er in de lijst staan, maar helaas weet ik niet van alles meer de exacte lokatie, het ging mij destijds voornamelijk om de BaseID's.
Mocht iemand nog aanvullingen hebben dan zal ik die graag verwerken!
Bericht door: Jeff2879203 op 30 augustus 2009, 15:31:49
Toch nog een beetje leven in dit topic. In de tijd dat de 'nieuwe' base-ids in pdw zitten heb ik alweer genoeg Base-IDs gevonden, hier in iedergeval al n:
BaseID: 0126 - Frequentie: 424.3375 MHz Nieuwegein Noord (staat ergens bij Laagraven of Lunetten)
Bericht door: Hunter op 30 augustus 2009, 15:36:11
Twee in Nieuwegein lijkt me persoonlijk een beetje sterk, de zender die al in de lijst stond staat redelijk centraal. Zal eerder ergens in Utrecht-Zuid zijn. Ook in het Centrum van Utrecht staat er 1 (424,3250/424,5625) maar daarvan weet ik ook helaas geen concrete lokatie. Kan hem wel ergens in het centrum plotten maar als je dan gaat inzoomen dan kom je misschien op een totaal verkeerde lokatie uit.
Bericht door: Jeff2879203 op 30 augustus 2009, 15:54:31
Dat zou kunnen best kunnen, ik weet in ieder geval dat het tussen Nieuwegein Noord en Utrecht zuid zit.
Bericht door: Arle op 31 augustus 2009, 10:40:05
Op het gebouw van ADM (51 57 33 04 07 18 (http://maps.google.nl/maps?f=q&source=s_q&hl=nl&geocode=&q=51+57+33+04+07+18&sll=52.469397,5.509644&sspn=3.433454,7.064209&ie=UTF8&ll=51.960029,4.121675&spn=0.027132,0.055189&t=h&z=14&iwloc=A)) staat de 0307 - Rotterdam - Europoort.
Links onder in het hoekje...  ;)
Bericht door: BlackBox op 31 augustus 2009, 11:56:39
Kijk dit vind ik een leuk initiatief Peter! Ik kan er ook wel wat toevoegen, als je de kaart voor iedereen of door jouw geselecteerde personen toevoegt kunnen we er met z'n allen iets moois van maken!
Bericht door: Arle op 31 augustus 2009, 15:12:20
Het is jammer dat we hier geen ID's kunnen uitwisselen, anders zou dat ook nog eens mooi zijn (veel worden toch wel in een flink gebied gebruikt). Maar die kaart is een mooi begin!
Bericht door: Hunter op 31 augustus 2009, 17:31:20
Europoort en Doorn zijn toegevoegd, met dank!
Bericht door: exLid057 op 31 augustus 2009, 21:29:38
424.0875 081D
 424.1375 0820
 424.1750 0802  Mobiel ook zeer goed te ontvangen
 424.3375 0819
 424.3625 0801  Mobiel ook zeer goed te ontvangen
 424.4000 0802  Mobiel ook zeer goed te ontvangen
 424.7000 0805  Mobiel ook zeer goed te ontvangen
 424.3125 0914
 424.3250 0833
 424.5625 0833
 424.6250 0912
Bericht door: Hunter op 1 september 2009, 07:03:46
Citaat van: "lpz-nl13161"
424.0875 081D
 424.1375 0820
 424.3375 0819
 424.3125 0914
 424.3250 0833
 424.5625 0833
 424.6250 0912
Dat is niet bruikbaar in mijn lijst, ik moet wel (zeker!) weten wat de bijbehorende lokaties zijn. Als ik nou ooit op 424.3375 zender 0819 ontvang, dan weet ik nog steeds niet welke zender het is. Dat is juist de opzet van de lijst, frequenties+ID+lokatie.
Bericht door: Hunter op 12 september 2009, 18:23:55
Vandaag Limburg-Noord in kaart gebracht : http://maps.google.nl/maps/ms?ie=UTF8&h ... 99384&z=10 (http://maps.google.nl/maps/ms?ie=UTF8&hl=nl&msa=0&msid=107486386994303181657.00047257888740b9dd47c&ll=51.403489,5.902405&spn=0.689642,1.399384&z=10)
Bericht door: Hunter op 15 september 2009, 12:41:44
En inmiddels ook 3 stuks uit Limburg-Zuid
Bericht door: Tom(zulu10) op 7 november 2009, 16:43:12
424.1375 ID 0309
Krijg hier berichten op van de omgeving Hoogvliet,Spijkenisse,enz iemand een idee waar de zender kan staan ?
Bericht door: Hunter op 7 november 2009, 17:56:34
424.1375 ID 0309
Je zou verwachten, gezien jouw lokatie en gezien de berichten die jij ziet, dat dat Vlaardingen moet zijn.
Ik heb Vlaardingen echter als 0334 in de lijst staan, maar misschien klopt dat niet...?
Dan zou je dus ook berichten uit Vlaardingen/Schiedam moeten zien..
Bericht door: Tom(zulu10) op 7 november 2009, 18:33:18
424.1375 ID 0309
Ik zie de meldingen van Vlaardingen en e.o  op 424.3600 ID0334 maar op de boven genoemde alleen maar meldingen van zeg maar district 10,11. (ambu met ritnr84630 zie ik nu voorbij komen)
Bericht door: Hunter op 7 november 2009, 18:37:25
Tom,
Verdorie, ik kan het zelf helaas niet 1,2,3 testen, maar ik zou zweren (heb het zelf ooit uitgepeild) dat Vlaardingen 2 kanalen had, te weten .1375 en .3625 (dezelfde combinatie als in Leiden). Misschien is het veranderd in de tussentijd...
Bericht door: Tom(zulu10) op 7 november 2009, 18:47:13
Tom,
Ja dat klopt ik had hem als Leiden met 0403 er in staan dus ik dacht even bijven volgen en toen kwamen deze meldingen over het scherm rollen. Heel interessant allemaal :P Misschien een zender er bij geplaatst in de buurt van Hoogvliet en dat die frequentie daar heen is verplaatst???????
Bericht door: Hunter op 7 november 2009, 18:49:10
Misschien, zie jij slave channels op 424.1375? Moet je Show Sweep Frames even aanvinken...
Bericht door: Tom(zulu10) op 7 november 2009, 18:54:15
Alles aangevinkt en krijg alleen dit.
[LIST OF NEIGHBOUR CHANNELS BaseID:0309]
Neighbour-01 : 424.0875 MHz / 414.0875 MHz
Neighbour-02 : 424.1125 MHz / 414.1125 MHz
Neighbour-03 : 424.3625 MHz / 414.3625 MHz
Neighbour-04 : 424.4250 MHz / 414.4250 MHz
Neighbour-05 : 424.4375 MHz / 414.4375 MHz
Neighbour-06 : 424.6250 MHz / 414.6250 MHz
CycleTime=10sec TimeToNext=9sec RssiPeriod=40 ?=60
EvaluateOthers=3RSSIperiods
BaseStatus=0 Cycle=14
TxPower=0dB RssiProcedure=ContinousMode RssiPeriod=100ms TimeToNext=9
MaxRepetitionFactor=3
BaseStatus=0 ScanTime=1.5sec BadBase=1dBµV GoodBase=4dBµV
BetterBase=6dBµV
Bericht door: bart van t hof op 9 november 2009, 21:02:47
Hallo luitjes ,
Peter we kennen elkaar al van eerdere communicatie , 424.1375 vertoont hier in Spijkenisse de beste ontvangst .lokale diensten hier in de straat (zuidzijde Spijkenisse ) loggen aan op deze frequentie. dat geldt eveneens voor Abbenbroek Simoonshaven en Oostvoorne bij  gelegenheid.
Dit even ter info.
Bart
Bericht door: Arle op 10 november 2009, 10:28:18
Citaat van: "bart van t hof"
Hallo luitjes ,
Dit even ter info.
Bart
Wat betreft Oostvoorne: waarschijnlijk is het dan zo dat een voertuig in Spijkenisse rijdt en dan een melding krijgt voor Oostvoorne. In Oostvoorne zelf is namelijk de zender van Europoort (307 = 424.6250) veel sterker in ontvangst.
Bericht door: Hunter op 10 november 2009, 13:08:00
Peter we kennen elkaar al van eerdere communicatie , 424.1375 vertoont hier in Spijkenisse de beste ontvangst .lokale diensten hier in de straat (zuidzijde Spijkenisse) loggen aan op deze frequentie. dat geldt eveneens voor Abbenbroek Simoonshaven en Oostvoorne bij  gelegenheid.
Mocht je nog vast kunnen stellen waar deze zender exact staat, dan ben ik erg benieuwd. Dan pas kan ik hem opnemen in de lijst :)
Bericht door: Jeff2879203 op 14 november 2009, 23:15:35
Heb hem eigenlijk al een tijdje maar 424.0875 ID 0137 is ook nog onbekend.. (Luid en duidelijk hier, ergens in Noord Utrecht geloof ik)
Bericht door: Hunter op 15 november 2009, 09:37:08
Dat zou als het goed is Hilversum moeten zijn. Wel verwerkt in mijn eigen lijst en op Google Maps maar nog niet in het overzicht in dit topic. Ga ik meteen even doen.
Bericht door: Hunter op 15 november 2009, 17:44:25
Vandaag zelf even gaan kijken; Kruisnetstraat Hoogvliet ;)
Bericht door: bart van t hof op 18 november 2009, 20:49:40
peter dank voor je info , ga hem nog eens bekijken . hij levert hier in ieder geval spectaculaire beelden op. momenteel diensten en kentekens aan terminal nrs aan het koppelen.
Bericht door: MarcoV op 1 december 2009, 19:58:13
Iemand toevallig de frequenties van de regio midden en west Brabant?? Ik zie zo snel niet staan.
Bericht door: Johan Beck op 10 januari 2010, 22:54:04
Afgaande op een nieuwe papieren plattegrond die ik hier heb ligt het net op de grens Bomenbuurt/Duinoord.
Bericht door: Bart op 17 januari 2010, 23:30:24
In Amstelveen ontvang ik de 424.3375 - BaseID 0211 (Schiphol) erg goed. Iets zachter, en volgens mij nog niet bekend, is 424.475 met BaseID 0204. Ik ben helaas niet in de gelegenheid om hem uit te gaan peilen.
Bart
EDIT: afgaande op de buurkanalen vermoed ik dat deze zender zich bij Aalsmeer in de buurt bevind. Mogelijk de bloemenveiling?
Bericht door: PA7AP op 10 februari 2010, 23:05:47
Kleine aanvulling
Bolsward was al vermeld maar staat nog niet in de lijst  424.5625  id:0A21
En op 424.3250 heb ontvang ik in Sneek id:091E.
Dat zou Emmeloord moeten zijn.
Bericht door: dannyij op 19 februari 2010, 10:10:28
Citaat van: "MarcoV"
Kijk, daar ben ik nu ook benieuwd naar. Alleen Tilburg is tot nu toe voorbij gekomen met de frequentie 424.2500. Iemand meer?  ;)
Bericht door: Asterix900 op 12 mei 2010, 00:50:17
Hoe kan ik op zoek gaan naar Mobitex-zenders in Vlaanderen? Hoe weet je of je wel een Mobitex-zender beet hebt?
Bericht door: Hunter op 12 mei 2010, 00:57:36
Citaat van: "Asterix900"
Als je PDW draaiend hebt, een ontvanger die je af kunt stemmen op de 424MHz band (voorzien van een discriminator uitgang) en PDW hebt afgestemd op "Mobitex" dan merk je snel genoeg aan de informatie in de titelbalk (en de signaalmeter) dat je beet hebt :)
Bericht door: Asterix900 op 12 mei 2010, 01:07:25
Ja roger, wilco. En bedankt!
Bericht door: Discriminator op 1 augustus 2010, 10:25:20
Ontvangen in R'dam-Oost: 424.0875, BaseID 0304. Lokatie onbekend. Zal straks naar de lijst met buren kijken, wellicht biedt dat een aanknopingspunt.
Bericht door: Bartje op 1 augustus 2010, 13:21:21
Citaat van: "Discriminator"
Wellicht Bergen op Zoom, die zender zit op die frequentie. Vanuit Bergen op Zoom ontvang ik ook de zenders Rottterdam, dus waarom niet omgekeerd?
Bericht door: Hunter op 1 augustus 2010, 18:08:44
Citaat van: "Bartje"
Je zou eens naar het ID kunnen kijken, als je in de gelegenheid bent :) Daarnaast lijkt het me nogal een grote afstand, temeer omdat de frequenties na enkele tientallen kilometers hergebruikt worden, of in elk geval de buurfrequentien (zoals Zoetermeer op 424.3250 en Den-Haag-CS op 424.3125) waardoor verre zenders lang niet altijd even goed te ontvangen zijn.
Bericht door: BlackBox op 22 september 2010, 21:24:05
Update:
020D=ONBEKEND 424.1375
0206=ONBEKEND 424.6325
0107=HARDERWIJK/BARNEVELD?
0914=APELDOORN? 424.3125
Bericht door: RenWvZ op 23 september 2010, 12:16:27
Citaat van: "BlackBox"
Update:
op 424.4750 ontvang ik (eindelijk :-) ) vanuit Nunspeet de zender Harderwijk
[LIST OF NEIGHBOUR CHANNELS BaseID:0107]
 Neighbour-03 : 424.1375 MHz / 414.1375 MHz
 Neighbour-04 : 424.1750 MHz / 414.1750 MHz
 Neighbour-05 : 424.4250 MHz / 414.4250 MHz
 Neighbour-06 : 424.5375 MHz / 414.5375 MHz
bevestigd 0107=Harderwijk=424.4750
Rene van Zon
Bericht door: maikelv op 27 november 2010, 01:35:43
424.2500 ID=070F
424.3375 ID=0710
Allebei nog geen idee welke locatie ze staan, maar daar kom ik nog wel achter  :wink:
Bericht door: maikelv op 27 november 2010, 21:55:44
Ok de 070F op frequentie 424.2500 is die van tilburg. Deze staat niet in het overzicht maar is in dit topic al wel vaker genoemd  :)
Bericht door: sfynx op 26 juni 2011, 01:40:51
Hallo allen,
Ik monitor Mobitex al een paar jaar in Utrecht centrum. Ging altijd prima tot afgelopen maandag (25-06-2011 rond 21.00u);
424.3250Mhz komt nog steeds goeddoor (klinkt hetzelfde als altijd) maar PDW lijkt het signaal niet meer te herkennen.
Naald zwabbert steeds van links naar rechts, maar het BaseID wordt niet meer opgepikt.
PC al helemaal gecheckt; alles staat hetzelfde, niets mee gebeurd.
Is er wellicht iets veranderd met de zender? Weet niet wat de lokatie is, maar ze zijn bij het Vredenburg flink aan het verbouwen?
Ik luister via de Serial Port, COM1, met 4-level interface en radiobutton op Slicer
Gegroet, Rob
Bericht door: Simonn op 18 november 2011, 15:15:40
Goedemiddag,
Ik vroeg mij af of iemand weet welke zender ik hier in Heino, OV oppak op 424,3125? Geen heel sterk signaal. Daarnaast een hele vage op 424,6312. Helaas geen mogelijkheid nu om PDW eraan te gooien. Heb het idee dat 424.3125 uit Zwolle komt. Zal volgende week eens kijken in Zwolle als ik er weer ben, mogelijk de Equinix/Vodafone mast? Of had het signaal dan duidelijker door moeten komen?
Gr, Simon.
Bericht door: Simonn op 29 juni 2012, 21:19:04
Het is dan wel een oud topic, maar nog steeds actueel volgens mij.
Zender 0914 moet haast wel Zwolle zijn in het oude Vodafone datacenter (Equinix). Hoge mast op de Marslanden, langs de N35. Daar zit volgens het Antenneregister ook een PAMR (Mobitex) zender. Frequentie 424.3125MHz, buurman-sites:
[list OF NEIGHBOUR CHANNELS BaseID:0914]
Neighbour-01 : 424.1375 MHz / 414.1375 MHz
Neighbour-02 : 424.1750 MHz / 414.1750 MHz
Neighbour-03 : 424.2500 MHz / 414.2500 MHz
Neighbour-04 : 424.4750 MHz / 414.4750 MHz
Neighbour-05 : 424.5375 MHz / 414.5375 MHz
Neighbour-06 : 424.5500 MHz / 414.5500 MHz
Neighbour-08 : 424.5875 MHz / 414.5875 MHz
Neighbour-09 : 424.7625 MHz / 414.7625 MHz
De scanner slaat uit op 5/5 signaalsterkte (al vertrouw ik die simpele metertjes in een BCT15x niet zo ::) met zowel een simpele rubberduck als een Diamond X-30 ). Alle andere zenders komen rond de 2/5.[/list]
Bericht door: cupcakepirate op 10 april 2018, 09:47:31
Goedemorgen,
Sinds kort ben ik als hobby bezig met MOBITEX. Ik heb een aantal vraagjes die jullie als veteranen vast wel kunnen beantwoorden.
Wat houdt precies het Network ID in? Het is standaard EB90, maar kun je dit ook veranderen? En heeft het berhaupt meerwaarde?
De volgende vraag is, ik krijg nu geen tekst o.i.d. heeft dit te maken met de afstand, of staan er instellingen niet goed?
En als laatste, het mobitex access number, is dit de gebruiker van het netwerk, of staat dit nummer voor iets anders?
Misschien dat jullie nog een goede website weten waar info vandaan te halen is?
Tot nu toe heb ik een baseID: 1E3E, iemand ook enig idee waar die vandaan komt? Is behaald in de buurt van Zoutkamp (GRO).
Bedankt bij voorbaat,
Een vrouw in nood  ;D
