Scannergerelateerd > Communicatienieuws
Comminucatie SpaceX
<< < (2/2)
TTT242:
Op google, voorwat het waard is…
What radio frequency does SpaceX use?
When the orbiter is above the horizon, air-to-ground voice on the UHF band can be heard either on 259.7 MHz or 296.8 MHz. Also, when the astronauts are performing an extra- vehicular activity (EVA), or spacewalk, the space- to-space communications are on 279.0 MHz.
Remon:
Iemand heeft "Space shuttle" vervangen voor "SpaceX":
https://www.nasa.gov/sites/default/files/167386main_AirtoGround06.pdf
--- Citaat ---Space shuttle air-to-ground communication is transmitted on one of two designated S-band frequencies. Because the S-Band voice is digitized, it is unintelligible. When the orbiter is above the horizon, air-to-ground voice on the UHF band can be heard either on 259.7 MHz or 296.8 MHz. Also, when the astronauts are performing an extravehicular activity (EVA), or spacewalk, the spaceto-space communications are on 279.0 MHz. To hear communications on these frequencies, it will, of course, be necessary to know if and when the space shuttle or International Space Station will be above the horizon at your location.
--- Einde van citaat ---
Erik1203:
--- Citaat van: Remon op 15 september 2021, 23:13:04 ---Iemand heeft "Space shuttle" vervangen voor "SpaceX":
dus met andere woorden er is nog hoop
Remon:
Ik denk juist het tegenovergestelde. Iemand geeft valse hoop door oude informatie aan te passen.
Navigatie
[0] Berichtenindex
[*] Vorige pagina
Naar de volledige versie
